how do you determine cubic inches?
Old May 22, 2005 | 08:48 PM
Dark Halo's Avatar
Default how do you determine cubic inches?
Just wondering what the formula that is used to determine cubic inches of a motor?
Old May 22, 2005 | 09:01 PM
Kano's Avatar
http://www.idavette.net/tech/inch_lit.htm
heres a calculator if that helps
Old May 22, 2005 | 09:03 PM
um, if you knew the bore and stroke of the engine in inches, then I suppose you could do a little math and get it. just find the surface area of the piston and multiply it by the height that the piston travels...by all means, correct me if I'm wrong
Old May 23, 2005 | 06:27 AM
PSM's Avatar
PSM
Nope your right.. simple geometry
Old May 23, 2005 | 08:20 AM
Black02Z71's Avatar
Bore X Bore X Stroke X 0.7854 X #of cylinders = Total displacement
So a 6.0L would be 4.00 X 4.00 X 3.62 = 57.92 CI X 0.7854 =
45.490368 X 8 cyls = 363.922944 CI
Old May 23, 2005 | 06:15 PM
shandy294's Avatar
Isn't it approx 60 ci/liter? Good if you don't care about being exact.
Old May 23, 2005 | 06:37 PM
pi(r)^2 (L) (# of cyl.'s)
r= 1/2 of bore
L=stroke
pi=3.14 of course
Old May 23, 2005 | 06:40 PM
blue 01's Avatar
If you don't know bore and stroke.To get you very close use this.
liters x61.02 = cubic inches
Old May 23, 2005 | 06:56 PM
Black02Z71's Avatar
There is no way to start with a litre value and be exact because it is already rounded off. A 6.0L is actualy a 5.963605283328L, times that by 61.02 and it does come very close 363.89CI vs 363.92 CI.
Old May 23, 2005 | 11:09 PM
blue 01's Avatar
If you read my post I said CLOSE, not anything about exact. There are a lot of people that don't know the bore and stroke on their motor or were to find it out. Most do know the liters on their motor. So this is a easy and fast way to get close to ci.
CD82
Oct 23, 2015 07:32 AM
GMCtrk
18
Oct 6, 2015 03:48 PM
Wolftrk99
Oct 2, 2015 08:17 AM
X_Racing1
Sep 30, 2015 01:59 AM
