Going bigger in California
Old Apr 7, 2006 | 07:22 PM
JOHN1L40's Avatar
Default Going bigger in California
Is it possible to put a 408 or bigger motor with cam and heads and still make it California emissions legal?
Old Apr 7, 2006 | 11:42 PM
Richard@WCCH's Avatar
FormerVendor
California DMV wouldn't know if the engine was a standard 6.0l or 408. The high tail pipe emissions will come from the extended overlap of the cam that gets used. If you keep the cam duration short and the lobe center wide, your tail pipe emissions will be similar to stock with a 408 or even a 427. Catalytic converters are mandatory and very necessary to meet the strict tailpipe test and must be retained. Cams with durations of 224º are about the maximum safe grinds that can pass the sniffer test. That cam in a 408 is a solid combination for a truck application.
Hope this helps.
Richard
Old Apr 7, 2006 | 11:48 PM
JOHN1L40's Avatar
Thanks, I guess Im going to start on a 408!!!
Old Apr 8, 2006 | 12:06 AM
jephs422's Avatar
don't forget that ALL of your original smog equipment will need to be hooked up too. there's the visual test as well. (not to point out the obvious)
Old Apr 8, 2006 | 12:20 AM
california....
Old Apr 8, 2006 | 12:45 AM
FormerVendor
Originally Posted by Soon2bSpooled
california....
............life's a beach............
Richard
Old Apr 8, 2006 | 01:02 AM
AintNoHo's Avatar
I have a couple of friends with camaros who passed smog with 224* duration cams, so I know it's doable. I noticed the STS in your sig, I may be wrong but I don't think any aftermarket turbo has a CARB exemption to pass smog. Might want to leave that off when you test.
Old Apr 8, 2006 | 02:42 PM
JOHN1L40's Avatar
Lucky for my truck they did get a CARB #. If I go with a 408 or bigger I might go N\A. This turbo is fun but I need more low end.
While Im on the subjet, for those of you who have purchased a complete 408 short block: Who is the best company to go through??
$A_Money$81
Mar 27, 2023 10:25 AM
old motorhead
Sep 29, 2015 08:22 PM
xxloudogxx
Sep 28, 2015 12:30 PM
brandon_6667
Sep 6, 2015 04:49 PM
Alco
Sep 4, 2015 04:08 PM
