Fuel pump making noise...
Old Jun 18, 2006 | 07:12 PM
ZR1 DREAMING's Avatar
Default Fuel pump making noise...
I can hear my fuel pump making noise even when the truck is off. Anybody know why this might be? The only way I can stop it is to disconnect the negative cable on the battery.
Is it a sign of failure? Why would it be so loud? The tank is about 3/4 full.
Old Jun 18, 2006 | 07:17 PM
dewmanshu's Avatar
Moderately Differentiated
Wait, I am confused...key in the off position?
Old Jun 18, 2006 | 07:22 PM
It does it with the truck on, off, and key out of the truck!
Old Jun 18, 2006 | 07:38 PM
TIM Z's Avatar
11 sec. Truck Mod
check your relay ??
Old Jun 18, 2006 | 07:46 PM
Mort's Avatar
Cool
Check the ABS control under the truck in the area of the driver's door. When they are going out they tend to run even with the key off. If you do a search you should find some more info on it and a place that rebuilds them if you are out of warranty. Well at least that is what it sounds like to me. Maybe pull the ABS fuse(s) or relay and see if it stops.
Old Jun 18, 2006 | 07:54 PM
You know, I remember seeing the ABS light pop on. I guess I'll do a search for this now.
Old Jun 18, 2006 | 08:15 PM
CNE's Avatar
CNE
It is probably the ABS pump running as said before. Pull out the ABS fuse in the underhood fuse block, if it quits, that's it. I see a lot of them in the dealership. The relay is internal in the module ans it sticks. The module is the black part bolted on top of the ABS assembly on the frame rail. It's easy to replace with the right tools, just 4 screws and 2 wire connections. I think it runs about $900 at the dealer though. You might check A/M availability.
Old Jun 19, 2006 | 07:20 AM
Well it is the "ABS module" thing. Once I get the new trans in I'll take it to a dealership since it's still under warranty, hopefully they'll service me after all of my mods.
Old Jun 19, 2006 | 07:28 AM
dewmanshu's Avatar
If not they will have to explain how your mods caused the issue. Congrats on finding it!
5.3Okasai
Mar 9, 2022 01:07 PM
5.3lSilverado
25
Aug 29, 2016 12:48 AM
MS3Z
Jul 30, 2015 06:17 PM
InsaneDomestics
Jul 27, 2015 02:42 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
