Fuel pump making noise...
I can hear my fuel pump making noise even when the truck is off. Anybody know why this might be? The only way I can stop it is to disconnect the negative cable on the battery.
Is it a sign of failure? Why would it be so loud? The tank is about 3/4 full.
Check the ABS control under the truck in the area of the driver's door. When they are going out they tend to run even with the key off. If you do a search you should find some more info on it and a place that rebuilds them if you are out of warranty. Well at least that is what it sounds like to me. Maybe pull the ABS fuse(s) or relay and see if it stops.
It is probably the ABS pump running as said before. Pull out the ABS fuse in the underhood fuse block, if it quits, that's it. I see a lot of them in the dealership. The relay is internal in the module ans it sticks. The module is the black part bolted on top of the ABS assembly on the frame rail. It's easy to replace with the right tools, just 4 screws and 2 wire connections. I think it runs about $900 at the dealer though. You might check A/M availability.
Originally Posted by Z06 DREAMING
Well it is the "ABS module" thing. Once I get the new trans in I'll take it to a dealership since it's still under warranty, hopefully they'll service me after all of my mods.
5.3lSilverado
25
Aug 29, 2016 12:48 AM
InsaneDomestics
Jul 27, 2015 02:42 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
