"Free" Mods List
Old Jun 8, 2011 | 03:15 PM
  #31
EasyE1986's Avatar
Originally Posted by 2nd Gen Fl 'bird
You're supposed to be taking out the ridges front and aft of the blade, which cuts down on the turbulence that they create. Not necessarily making the hole larger. Yes, you will pick up power5-7hp usually. Throttle response is the "biggie" on noticible improvement. Said before, every little bit helps.
Im guessing here but it will help more on a FI motor than N/A.
Old Jun 8, 2011 | 03:31 PM
  #32
Spoolin's Avatar
GFYS and STFU
We should make the first post, along with a few of the following ones a sticky or throw it in the new section on How-to's.
Old Jun 8, 2011 | 08:22 PM
  #33
Huntingman2706217's Avatar
not understanding the whole drilling brake thing or whatever? what the heck does this do?
Old Jun 9, 2011 | 05:39 PM
  #34
flippindabird's Avatar
id like some elaboration on that myself hunter
Old Jun 10, 2011 | 02:07 AM
  #35
darnie's Avatar
quick question the "lip" on the front side is that saposto be smothed down? left alone or grinded to match? i dont have anyone around here to ask so i wanna make it clear before i go tearing into anything else haha thanks guys
Old Jun 10, 2011 | 12:41 PM
  #36
it should be pretty obvious for you, nothing too crazy your just creating a smother transition, your not boring anything out lol just make it look the way GM should have done it from the factory nice and smooth so the air doesnt have as much obstruction
Old Jun 10, 2011 | 01:05 PM
  #37
Nuclear Endless's Avatar
Yeah... the write up section
Old Jun 14, 2011 | 11:53 AM
  #38
2nd Gen Fl 'bird's Avatar
I would say the gain would be more on a FI motor. How much? I don't know. Forced induction "over comes" poor air flow TO AN EXTENT. The more "fluid" airflow is into any motor or either type of induction will produce more power.
Old Jun 14, 2011 | 11:59 AM
  #39
The "lip" on the front side and the back side of the blade needs to be smoothed out. Grind with bit then use sanding roll to finish out. Do not touch the area where the blade seals with the bore of the TB. You're screwed if you mess with that.
Old Jun 14, 2011 | 02:33 PM
  #40
darnie's Avatar
kk awesome thanks man, ill see what i can do
