"Free" Mods List
#61
12 Second Club
How does the tube vent? It isn't open anywhere so it just connects left to right & I'm not seeing how having the 2 sides connected is any different than them just being blocked off. And since it is for coolant water passage, it can't have a vent or the coolant would leak.
#62
Kinda like when people convert their LS engines to carbs.....There goes that crossover & I don't hear anything about anyone adding a crossover tube for the carb conversion.
#63
dont pull the IAC and cycle the key, it will shoot that piston right out. figured that one out the hard way
#64
12 Second Club
Actually I think it is just for heating the throttle body & a lack of the crossover would do nothing to hurt the engine in any way.
Here is some reading for you.
LS1 steam lines from heads - LS1TECH
#65
I don't know why you are so focused on this. For the record you could convert to carb and still keep the steam tube, as far as I know that is how people do it.
I'm new to this whole LS-series engines & trucks & I learn b y KNOWING, not just 1 post by 1 person saying "Do it." Too much disinformation on the 'net to trust 1 post by 1 person saying something. Thanks for posting that link. It explains it well. I'm not on LS1tech.com. Instead of blocking them off I'll keep mine open but connect them with 1 hose & bypass the TB even though mine is just a 4.8 & I'm not trying crank out huge horsepower #s out of it, which according to Post #4 I'd be fine blocking them off altogether but again.....also not gonna go by 1 persons 1 post saying that I can.
#66
12 Second Club
Focused? I dunno about that, but I know I'm not spending $20 on a kit if 2 Autozone plugs & couple clamps will suffice. Or just buying 1 longer hose to connect the 2 instead of jerry rigging a splice tube instead of doing it right & just replacing everything with 1 longer piece of tube. I do things once & do them right.
You're right, according to post #4 a stock power level vehicle may have "little" consequence. However, I did not assume your goal was to make stock level power and that was never clarified until now.
Lastly, regarding doing things "right", I guess in my opinion there is nothing wrong with doing things the way that works. Thousands of people have connected the hoses together and made an absolute ton of power with no issues with the hoses coming apart, etc. It is far from the most glamorous solution possible, but it gets the job done and I'm not building a show truck at this point.
GM1697
09-09-2015 01:52 PM
muncie21
09-07-2015 09:55 PM
