Diesel vs. Gas - which is cheaper to mod to 11s and under?
Old Oct 11, 2005 | 08:54 PM
jeremys's Avatar
Default Diesel vs. Gas - which is cheaper to mod to 11s and under?
Even if I had to go with a Dodge diesel, which would be cheaper to run 10s/11s: an older (like 99 or older) cummins dodge or a RCSB chevy half ton?
I know diesels have some real easy tuning mods, but they are heavy as hell and need a lot of $ to get past 12s, correct?
Old Oct 11, 2005 | 08:58 PM
5.3AlmnBlk's Avatar
a 1/2 ton definatly they can get 12's n/a and then add a turbo or super and upgrade that tranny you will see 12.0's soon.
Old Oct 11, 2005 | 09:28 PM
TieRod's Avatar
Probably cost $1500 to get a D-Max in the high 11's. $1000 for a programmer and $500 for a nitrous kit. But it will cost $5000 to get the Ally to hold up.
Old Oct 11, 2005 | 09:35 PM
BMDMAX's Avatar
With the Duramax you can dip into the 11's, even in a crew cab with the following:
Race Allison 1000 - 5 to 7K depending on brand
Programming - 1,200
Exhaust - 600
Nitrous system - 500 to 1,200 depending on your system preferences
You will burn pretty much 8 to 10K depending on how much you want to customize your rig. How does that compare to the gas curve?
Old Oct 11, 2005 | 09:47 PM
jeremys's Avatar
if im not mistaken, it will cost around the same for mods? this is what i figure for a gas engine (say a 5.3 in a RCSB)
headers and cutout - 500
tq converter - 500
cam - 500
dyno tune - 500
used 4L80E - 1k?
intake and misc boltons - 500
injectors and pump - 500ish
and another 4-5k for nitrous and FI
Old Oct 18, 2005 | 11:39 PM
04BlackGmc's Avatar
10 Second Club
i would go Diesel any day.
Old Oct 19, 2005 | 05:27 PM
2000SIERRA's Avatar
Agreed
I am planning on doing something similar to this too, and after doing alot of reading, I would think a diesel would be easier and cheaper, maybe not alot cheaper, but..... Also, I like the look of lifted trucks, and I've seen duramaxes run some damn good numbers on 33-35" tires, and most of the gas engines are running stock size tires. I'm not sure how you want to set the truck up, but I have always wanted to go fast and be big and it seems a diesel is the way to go
Old Oct 20, 2005 | 12:00 AM
04BlackGmc's Avatar
10 Second Club
Originally Posted by 2000SIERRA
Agreed
**** your just fine with your truck it dont matter its not fast.
Justin87gn
Sep 10, 2015 12:06 PM
Dezmo
Sep 9, 2015 02:09 AM
jleews6
Sep 8, 2015 10:17 AM
bisqikss
Sep 8, 2015 03:35 AM
iregret
Sep 7, 2015 01:20 PM
