Diesel vs. Gas - which is cheaper to mod to 11s and under?
Even if I had to go with a Dodge diesel, which would be cheaper to run 10s/11s: an older (like 99 or older) cummins dodge or a RCSB chevy half ton?
I know diesels have some real easy tuning mods, but they are heavy as hell and need a lot of $ to get past 12s, correct?
With the Duramax you can dip into the 11's, even in a crew cab with the following:
Race Allison 1000 - 5 to 7K depending on brand
Programming - 1,200
Exhaust - 600
Nitrous system - 500 to 1,200 depending on your system preferences
You will burn pretty much 8 to 10K depending on how much you want to customize your rig. How does that compare to the gas curve?
Programming - 1,200
Exhaust - 600
if im not mistaken, it will cost around the same for mods? this is what i figure for a gas engine (say a 5.3 in a RCSB)
headers and cutout - 500
tq converter - 500
cam - 500
dyno tune - 500
used 4L80E - 1k?
intake and misc boltons - 500
injectors and pump - 500ish
and another 4-5k for nitrous and FI
tq converter - 500
cam - 500
dyno tune - 500
used 4L80E - 1k?
Originally Posted by 04BlackGmc
i would go Diesel any day.
I am planning on doing something similar to this too, and after doing alot of reading, I would think a diesel would be easier and cheaper, maybe not alot cheaper, but..... Also, I like the look of lifted trucks, and I've seen duramaxes run some damn good numbers on 33-35" tires, and most of the gas engines are running stock size tires. I'm not sure how you want to set the truck up, but I have always wanted to go fast and be big and it seems a diesel is the way to go
Originally Posted by 2000SIERRA
Agreed
iregret
Sep 7, 2015 01:20 PM
