Charging questions??
Old Dec 19, 2008 | 09:56 PM
outlawz2004's Avatar
My 04 wont run with it disconnected.
Old Dec 20, 2008 | 02:47 PM
budhayes3's Avatar
PT's Slowest Truck
I'd definitely double check all of the fuses, I'd think that circuit would be protected. I believe that the newer trucks have a sort of alternator duty cycle that is PCM controlled, could be something in that circuit or even the tuning. Also check the batt cables for corrosion.
Old Dec 20, 2008 | 03:35 PM
BuyAmericanIron's Avatar
Pulling a battery cable off while the truck is running used to work in the 60's, but I would strongly recommend against that practice with a computer controlled truck. You are liable to send a voltage spike through the system and damage a component far from the alternator. Have your battery load and alternator load tested. Good luck
kalikid06
20
Oct 13, 2015 07:37 AM
Justin87gn
Sep 10, 2015 12:06 PM
bisqikss
Sep 8, 2015 03:35 AM
iregret
Sep 7, 2015 01:20 PM
SWINGRRRR
Sep 3, 2015 07:49 PM
