belt size for 145a alternator
Old Jul 11, 2010 | 06:05 PM
53RUSSELL's Avatar
Default belt size for 145a alternator
My truck came with stock 105 alternators and I up grade to 145a. Now I have this squealing belt that can't get it to stop. I put a belt for 130a alternator on truck. What belt size are you guys running with the 145a alternator? Thanks.
Old Jul 11, 2010 | 06:40 PM
1Bear's Avatar
The belt size for the 145amp should be the same as the 130amp to the best of my knowledge as they have the same size case. I don’t know for certain the belts are exactly the same length but when I upgraded from the stock 130amp on mine to a 145amp, I used the same belt and never had an issue. I don’t recall what size belt that was, as I’ve had the Radix on there for 4 years unfortunately.
I hope for your sake you get it figured out, as I for one can't stand belt squeaks and squeals.
Old Jul 11, 2010 | 07:04 PM
53RUSSELL's Avatar
Thanks for input. I know it bugging **** out me right now.
Old Jul 12, 2010 | 02:46 AM
budhayes3's Avatar
PT's Slowest Truck
Here's the part number for the belt that I've been using with my 145amp alt for over 5 years: 12576451
It's been working fine, except for recently, after I swapped in my Circle-D billet multi-disc...now it squeals for a split second when lock up engages since it hits so hard and the lockup is instantaneous. I may try a shorter belt or a new tensioner, or just a new belt of the same part number, since it's over 5 years old, and the truck sat for 18 months which may have contributed to it drying out.
Old Jul 12, 2010 | 11:18 PM
53RUSSELL's Avatar
Is this a dealer part #??
Old Jul 12, 2010 | 11:31 PM
53RUSSELL's Avatar
Would you happen to know the length on that belt??
Old Jul 12, 2010 | 11:47 PM
budhayes3's Avatar
PT's Slowest Truck
I don't know the length, but it is a GM part number. I actually got that part number here over 5 years ago, from creederado, a member who hasn't posted here in a long time.
Old Jul 13, 2010 | 12:05 AM
00ChevyScott's Avatar
Wearin' da big hat
Gates pt number
K060930 13/16" x 93 5/8"
Old Jul 13, 2010 | 12:09 AM
Bigredmariner's Avatar
Here's a Dayco pt number too. 5060930
GMCtrk
Oct 5, 2015 11:18 AM
SlvrSierra4.8
Oct 1, 2015 09:39 PM
twake_410
Sep 25, 2015 10:09 PM
Closer_2001
Sep 24, 2015 09:15 PM
97_ek
Sep 23, 2015 09:16 PM
