6.0 build for blower
Old Jan 24, 2020 | 12:25 PM
  #131
terravast4's Avatar
looks like fun
Old Jan 24, 2020 | 12:33 PM
  #132
GREENSIERRA's Avatar
Hell yeah, that thing looks like alot of fun!
Old Jan 24, 2020 | 12:39 PM
  #133
stroker87's Avatar
ha! by the speedo and tech i bet you laid some solid stripes down
was you hitting the limiter it sounded like it was braking up a little up top?
Old Jan 24, 2020 | 12:42 PM
  #134
dantheman1540's Avatar
Thanks guys its getting there!
The breaking up was the 2 step set to 5500. I like to set it a little lower if I plan to do burnouts and its quicker to adjust than in HPT. Plus it sounds cooler than a normal rev limiter.
Old Jan 24, 2020 | 12:50 PM
  #135
stroker87's Avatar
so your 2 step is on all the time?
i was thinking of getting one for my zo6 i asked around and was told it just set for launching and not active when shifting? im on the fence about one since i was in full send mode next to a built cts-V bumped the rev limiter on a shift and timing chain left the party @ 7100rpm's lol
Old Jan 24, 2020 | 01:08 PM
  #136
There are 2 ways to set it. You can have it activated for a launch where it will then shut off after the launch so you can leave at say 4,000 and then once you've launched the 2 step shuts off and reverts the limiter back to whatever the ECU is programmed to. Or you can set it to have on all the time which is what I do because I haven't played around with it enough to figure out the launch setting nor have I been to the track.
Old Jan 24, 2020 | 01:12 PM
  #137
arthursc2's Avatar
oof. What chain? And what damper?
For those curious there is the LS2 damper which is inside the chain, and there is the LY6 damper which is a spring loaded deal on the outside of the chain. I selected the LY6 style for me build so I can have more **** break. I mean so I can have the chain constrained in the direction it wants to grow. Silly autocorrect
Old Jan 24, 2020 | 02:51 PM
  #138
stroker87's Avatar
ls6 so no dampener my car being 01 block was not drilled, chain was the ls2 that was installed when i swapped cams less then 10k on it was bought from a local GM dealer. the 416 will have a timing chain dampener and a better chain! expensive lesson
Old Jan 24, 2020 | 09:04 PM
  #139
Wrangled enough neighborhood drunks to get the bed and tail lights on. Needed gas badly so drove it to town and even made it to a taco shop about 35 miles total.
Yes I know the body looks like
Old Jan 24, 2020 | 11:53 PM
  #140
00pooterSS's Avatar
I just read this for the first time.
Awesome work on the engine build man, you did a killer job and that truck seems like 2 full buckets of fun. I love it
