6.0 build for blower
Old Apr 24, 2020 | 10:31 AM
  #211
dantheman1540's Avatar
No I don't ever plan to run 4x4 around town just for the fun of it. Leaving hot from a light in 4x4 would be fun tho. I have Kryptonite tierods, double sheer idler arm, Cognito pitman arm support, and a red head box so steering I am not concerned about. Diff and T case were both rebuilt about 2 years ago as well. I was more concerned about the OEM drive shafts.
Old Apr 24, 2020 | 11:13 AM
  #212
arthursc2's Avatar
give her hell! Sounds like she can take it
Old Apr 24, 2020 | 11:17 AM
  #213
Ok remind me of this in a few months when It runs and drives again.
Old Apr 24, 2020 | 11:31 AM
  #214
00pooterSS's Avatar
The main killers are real high/hard clutch dumps, and wheel hop. If you avoid those the axles can take a ton of power. So yeah a slip/roll on should be fine.
Old Apr 24, 2020 | 02:11 PM
  #215
2002_Z28_Six_Speed's Avatar
There is supposed to be some magic tcase that is AWD with a lockable low range. I don't know if the 32 spline adapter is compatible with it. If so that sounds like the holy grail to me.
Old Apr 24, 2020 | 02:29 PM
  #216
I have a feeling I will need limit straps for the front it has so much down travel the CVs nearly come out of place. However at ride height the steering and CV angles are pretty flat.
Huh I haven't heard of that unicorn yet. I really just prefer a floor shift box I've never had any problems with it and I've used 4x4 hi/low in dirt under high load and power many times without failure. Ole girl loved pulling a trailer or truck through sugar sand.
Old Apr 24, 2020 | 07:42 PM
  #217
_zebra's Avatar
makes children cry
Originally Posted by dantheman1540
2.10 60' and an ET of 10.3 is what I ran in Sturgis when it was bolt ons and a BBP tune. Of course the NV3500 wouldn't let me into 3rd so I just held second at 62mph and redline through the trap.
weaksauce! if you double-clutched & didn't shift like a *****, you could've at least pulled off a slow-***** 9.67 @ 70 like my inexperienced butt.
Would you guys feel safe leaving in 4x4 with a 6.0/408 and blower? Even with the 33s and basically stock axles and drive shafts? I don't mean launching it with a 3k clutch dump but maybe slip the clutch and then lay into it. I've been to sissy.
going straight's fine
just call the same guy that makes the 32spline inputs for 4L80 swaps. the NP149 is what you need if you're wanting AWD.
Old Apr 26, 2020 | 03:12 PM
  #218
Here is the info on the Tcase.
http://tcase.rsgear.com/articles/2008_12.pdf
Shtbox
Apr 26, 2017 05:27 PM
texasglock23
Feb 28, 2015 03:21 PM
moregrip
Dec 7, 2012 01:43 PM
Red03SilSS
Jul 19, 2010 03:31 PM
Ryan23silverado
Mar 31, 2003 07:11 AM
