418 build update pics and broke a ring
Old Jan 11, 2006 | 06:50 AM
  #141
white1's Avatar
The only reason why I say the extra little stroke MAY be worth it is to be different I hate doing the same thing everyone does too many people ahve 408s I cant think of anyone off the top of my head with one.
Maybe now you know why
Old Jan 11, 2006 | 06:56 AM
  #142
gomer's Avatar
11 Second Club
I know an Alabama guy that's about to have a bigger engine in his truck than you ... he's trading his little 408 nitrous motor in on it.
Old Jan 11, 2006 | 12:00 PM
  #143
Yelo's Avatar
Having the crank rebalanced huh.....Gee, wonder why
Old Jan 11, 2006 | 12:14 PM
  #144
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Um Yelo I was going to run it the way it was but since I pulled it out anyway I figured I would go ahead and get it balanced. No need for the sarcasm.
Gomer this summer the motor is going to get supersized and unless your buddy is getting the block sleeved I doubt he will have a bigger motor
So Tony is ditching the 408 huh? Would be fun the next time I come back up to AL to run him, would be a pretty fair race
Old Jan 11, 2006 | 12:18 PM
  #145
gomer's Avatar
11 Second Club
C5R
Old Jan 11, 2006 | 12:31 PM
  #146
1slow01Z71's Avatar
Originally Posted by gomer
C5R
awww ****
So Tony is finally going to get serious
Ill still race him the next time I come up here
Its goign to be a beast for sure. What is the largest a C5R block can be punched out to? Dont know too much about those blocks
What is he going to be selling off the 408?
Old Jan 11, 2006 | 02:20 PM
  #147
TurboGibbs's Avatar
It is the 4.125" bore and 4" stroke I believe(427). It is basically what the LS7 is patterned after.
Old Jan 11, 2006 | 02:29 PM
  #148
TurboGibbs's Avatar
Exactly why everything was done has been clearly stated. Was it the best thing to do, no. But grinding the throws did solve the problem of the crank hitting the bottom of the piston under the wrist pin, when in a pinch. It just so happens that it was hitting the piston skirt as well at BDC when the piston rocked as it started back up. Basically the piston was moving and hitting the crank not the crank was hitting the piston, where there was .050 clearence before.
Comments like that are just not necessary.
Also, the crank is going to have to be rebalanced anyhow after some of the skirts are milled off for clearence, which will lighten the rotating assembly.
Old Jan 11, 2006 | 02:30 PM
  #149
gomer's Avatar
11 Second Club
That is correct.. without all the headaches of an aftermarket resleeved LSx block.
Old Jan 11, 2006 | 06:19 PM
  #150
Yelo's Avatar
As I stated before...I think it's GREAT that Cody is attempting a rather compicated first-time build on his own....
BUT....before you attempt even an OIL CHANGE you should know what you are doing !!!, SOMEONE here should have warned him LONG before I made my comments that GRINDING MATERIAL OFF OF A BALANCED CRANKSHAFT WITH A GRINDER TO PROVIDE PISTON CLEARANCE IS A BAD IDEA !!!!. And having a machine shop that has NEVER worked on a Gen III do THIS ONE as their first probably wasn't the best idea ever......a more experienced shop would probably have saved Cody a world of heartache
just my .02......
