418 build update pics and broke a ring
Old Jan 10, 2006 | 07:06 AM
  #121
CurtD's Avatar
10 Second Truck Club
Man that sucks big time. Just keep lookin at the end result it will be worth it
Old Jan 10, 2006 | 07:17 AM
  #122
JimS's Avatar
My mentor shakes his finger at me and tells me "don't get rammy"!
Seems he thinks I have a tendancy to get "rammy" (pronounced ram e ), or let my emotions control my actions, get excited or upset and then get "rammy". I get the feeling you maybe get that way sometimes. Be cool, be careful, stop and take a deep breath. You are a really bright guy. Let your intelligence guide your actions. Don't get rammy. Regards, Gramps
Old Jan 10, 2006 | 07:33 AM
  #123
67SS509's Avatar
Originally Posted by mjhoward
They were custom made by je and all were clearenced for the reluctor wheel. The thing was rotated multiple times on the stand and no clearence issues were obvious. It basically has to be something like the oil pump because I didn't rotate it myself after the oil pump and windage tray were installed. It is knocking like a spun rod sounds. It got a little quieter with the windage tray clearenced properly of course. I don't see how it spun a rod of course having checked the bearing tolerances and the engine hasn't seen over 1500rpm yet. It could be anything at this point. We will all soon find out.
I have seen a few spin a rod bearing right after cranking (not any I built). The crank has a radius at each end of the throw and the bearings are marked upper and lower and clearanced for this. If you get one wrong on assembly it will seem fine but will sieze and spin the bearing when you crank it.
Old Jan 10, 2006 | 08:22 AM
  #124
Scrapin'4.8's Avatar
well think of it this way, if we ever have a "See who can pull their motor the fastest" Contest, u'll smoke all of us, but really that sucks ***, but it will get better, it has to, sooner or later there won't be anything else on it that'll tear up and u'll be good to go
Old Jan 10, 2006 | 09:27 AM
  #125
white1's Avatar
Dude that really sucks. Ive been in your shoes, but with the transmission issues. Trying to rush so I could get to work the next day, then blow another. At least when its all said and done, you will be able to look back at it and say "Yep uh hu dangole Ididthat therehot rod truck yup."
Old Jan 10, 2006 | 10:24 AM
  #126
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
The bearings were put in properly. There are little notches that go into each other for the different bearings and we put them in on the right sides Im sure of that.
LOL at Jim thanks for the advice
White1 yeah I think I probably have the record drop it in one day pull it out the next pretty much. Parish has had his motor in and out more times than I ahve though so I ahve some catching up to do
Oh and Jim just the motor comes out its a hell of alot easier especially since Im 4wd. You gotta make sure when you put the motor in that the converter is fully seated and take it easy and get it lined up perfect with the bellhousing thats all.
Old Jan 10, 2006 | 10:33 AM
  #127
white1's Avatar
Um yea make sure of that
Old Jan 10, 2006 | 10:35 AM
  #128
1slow01Z71's Avatar
that third "click" into the trans is a major PITA isnt it Matt?
Old Jan 10, 2006 | 11:26 AM
  #129
white1's Avatar
I think it was fully seated, just all the bumping and banging around (I forgot the vise grips ) it came out of that last "click"
Got a two for one though. Screwed the TC and tranny pump.
Old Jan 10, 2006 | 04:29 PM
  #130
1slow01Z71's Avatar
that does suck I just screwed up my pump rotor up.
