418 build update pics and broke a ring
#141
The only reason why I say the extra little stroke MAY be worth it is to be different I hate doing the same thing everyone does too many people ahve 408s I cant think of anyone off the top of my head with one.
Maybe now you know why
#144
Tin Foil Hat Wearin' Fool
Um Yelo I was going to run it the way it was but since I pulled it out anyway I figured I would go ahead and get it balanced. No need for the sarcasm.
Gomer this summer the motor is going to get supersized and unless your buddy is getting the block sleeved I doubt he will have a bigger motor
So Tony is ditching the 408 huh? Would be fun the next time I come back up to AL to run him, would be a pretty fair race
#145
#146
Originally Posted by gomer
C5R
So Tony is finally going to get serious
Ill still race him the next time I come up here
Its goign to be a beast for sure. What is the largest a C5R block can be punched out to? Dont know too much about those blocks
What is he going to be selling off the 408?
#148
Originally Posted by Yelo
Having the crank rebalanced huh.....Gee, wonder why
Comments like that are just not necessary.
Also, the crank is going to have to be rebalanced anyhow after some of the skirts are milled off for clearence, which will lighten the rotating assembly.
#149
Originally Posted by mjhoward
It is the 4.125" bore and 4" stroke I believe(427). It is basically what the LS7 is patterned after.
#150
BUT....before you attempt even an OIL CHANGE you should know what you are doing !!!, SOMEONE here should have warned him LONG before I made my comments that GRINDING MATERIAL OFF OF A BALANCED CRANKSHAFT WITH A GRINDER TO PROVIDE PISTON CLEARANCE IS A BAD IDEA !!!!. And having a machine shop that has NEVER worked on a Gen III do THIS ONE as their first probably wasn't the best idea ever......a more experienced shop would probably have saved Cody a world of heartache
just my .02......
... he's trading his little 408 nitrous motor in on it.
