Transmission issue or ?
Old Dec 5, 2005 | 11:29 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
Default Transmission issue or ?
With the gear selector in D and doing 45-50 mph i will be locked in OD. If i gently increase throttle i can hear the engine (?) clinking, like it is lugging! The tranny wont immediately downshift unless i give it more throttle, and then the ping stops. I know if i drive in 3 i dont have this issue.
What's goin' on? Is it the tune? I have increased line pressure to 35% and upped shift point 200 rpm only.
Old Dec 5, 2005 | 01:38 PM
gonzo 6.2's Avatar
Who's tune? yours or westers?more info would help or an updated sig.
Old Dec 5, 2005 | 01:42 PM
trever1t's Avatar
Wester's tune. Sig is up to date. Noticed this after changing to 3.73 gears, both before and after tune was updated for gear change.
Old Dec 5, 2005 | 03:09 PM
quicksilverado's Avatar
The noise you hear is the load on the engine when the converter is locked. When you give it more gas and it down shifts to 3rd the engine is not under as much load so you don't hear the noise of the engine because the load is greatly reduced.
Old Dec 5, 2005 | 03:15 PM
trever1t's Avatar
So that ping is normal and wont hurt anything? No worries? Cool! Thanks
Old Dec 5, 2005 | 03:33 PM
Depends on the tune. I can feel mine strain when it locks in OD under light throttle.
Old Dec 5, 2005 | 03:54 PM
StrokerAce03's Avatar
Mine does the same thing and its stock. Its lugging because the overall gearing is really high at this point since you're in OD and you haven't given it enough gas to allow the tranny to downshift. Just punch it; it'll go in to second then
Old Dec 5, 2005 | 04:01 PM
gonzo 6.2's Avatar
I have increased line pressure to 35% and upped shift point 200 rpm only"
When you said "I" you ment westers.That is where the confusion was.
The tune is set to not unlock the converter right away,until more throttle pressure,yours sounds normal but could be adjusted out.
Old Dec 5, 2005 | 04:09 PM
trever1t's Avatar
As long as there's no risk of damage from the occasional incident then i'm cool. I drive in 3rd around town most of the time anyway. I was just concerned i had some issue. Thanks alot!
zblee
63
Jun 10, 2023 01:25 PM
XL7
May 5, 2022 01:48 PM
LCHEE
Oct 24, 2020 04:10 PM
Go5.3tt06
Sep 12, 2015 09:29 AM
