08 4L60E to 4L80E 4X4
Old Jul 29, 2015 | 07:41 PM
XL7's Avatar
XL7
Default 08 4L60E to 4L80E 4X4
I have a 2008 1500 Silverado 4X4 with a 4L60E. The transmission has been rebuilt twice. I am in the process of putting a trick turbo kit on so needles to say something needs to be done with the transmission. So I have been looking at doing a 4L80E swap but haven't been able to find anything on 4X4 swaps for that year/ style. Lots on guys with 2WDs. Has any one been able to do a swap on a 4X4? I have read about not being able to do segmented swaps on 08 computers so guys have been using van PCMs. Well vans didn't come with 4x4 that I know of. Is it just the 08 that have issues with segment swapping? Could I maybe use a newer PCM that would work with segment swapping or has some one figured the segment swapping issues out? Or dose it look like I am stuck with building a 4L60E up and hoping it holds together. Any ideas or input?
Thanks
Old Jul 29, 2015 | 08:57 PM
JordanH's Avatar
Restricted
This guy is in the middle of doing 4x4 80e swap on a 07-08
https://www.performancetrucks.net/fo...roject-516897/
Old Aug 6, 2015 | 07:12 AM
alex226's Avatar
What are you tuning with?
Old Mar 10, 2021 | 06:56 PM
THE.DOC's Avatar
Registered User
I don't know if this will still work, i did a conversion from a non pc truck to a latter model compurterized motor in my
86 chev c-10 and i used lite emmiting diods with the proper ohm draw in circuits that were not used and it worked perfectly.
I hope that will help.
The.doc
Old Mar 23, 2022 | 11:09 PM
Shift1208's Avatar
Try PCM of NC I just used their harness for a 2010 Silverado 2wd. I don't think it says anything in their website about 2 or 4wd. The tranny shop and tuner didn't believe it could be done without a segment swap but this worked. There customer service is great to answer questions over the phone.
https://www.pcmofnc.com/product/pcm-...rsion-harness/
Old May 4, 2022 | 09:49 PM
96caprice454's Avatar
I want to make sure I'm reading this correct. So I don't have to add the wires for the extra speed sensor into the pcm anymore? I know you used to have to add the wires for the extra vss sensor into the pcm.
Old May 4, 2022 | 10:14 PM
Shift1208's Avatar
Correct. The front input sensor does not need to be wired back to the PCM. If you have questions there customer service is real good give them a call.
Old May 4, 2022 | 10:35 PM
Thank you. I just did that. I have a turbocharged 07 avalanche that Im going to be swapping a 4l80e into because my 60e just **** the bed on the way to work. Thanks for the info. This will make it just a little bit easier.
Old May 5, 2022 | 01:48 PM
Shift1208's Avatar
Right on glad it helped. One other thing I have experienced is after the swap I'm getting a drive line vibration. I have a 2 piece driveshaft and the crossmember the shop used I think the tail housing sits a bit higher than 4l60 did. So that may be why. Haven't really been able to get into it.
Bramante98
Jun 7, 2016 04:41 PM
CROOKS
Dec 31, 2013 01:35 AM
Boosterado
Jan 25, 2012 07:57 PM
Wonderer876
Feb 19, 2010 05:14 PM
