temp increase after new stall??
Old Aug 7, 2006 | 08:23 PM
ap2002's Avatar
Default temp increase after new stall??
is it normal to see a trans temp increase after a converter swap???
I went from a 2800 to a 3200 stall, before temps would hang from 170-180 now its more like 190-200degrees??? I know the weather is hot down here so that does not help..... I have a small tranny cooler, I think I will be going with a bigger one...
Old Aug 7, 2006 | 08:25 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
yup! Your just slipping at any speed under the rated stall so that causes heat to build.
Old Aug 7, 2006 | 08:45 PM
Wilde Racing's Avatar
How do I change this text
If the converter is not locking it will be way hotter......
in town it will be hoter, but at highway it should be about the same (lock all the time) maybe a a little bit hotter but not much..
Old Aug 7, 2006 | 08:50 PM
ap2002's Avatar
well its weird cause it will stay the same at highway speeds?? I going to get a re-tune this wednesday with nelson, so he can tune it out...
Old Aug 7, 2006 | 09:19 PM
RoosterMcCandles's Avatar
That is completely normal. In case you don't already have one, a tranny cooler would definitely help you out and extend transmission life...
Old Aug 7, 2006 | 11:18 PM
do you know what GVW your trans cooler is rated to. i have a "3200" ~3400 stall with a 20-22000 GVW cooler. my temps quickly rise to about 150, slowly to about 180 and usually max out right before 195 if im doing ALOT of stop and go driving but those temps arent bad. im looking into a transcooler from OPT for 51.99 30000 GVW. comes with installation kit too, PM if you want the link.
Old Aug 8, 2006 | 03:59 AM
bluecajun5.3's Avatar
11 Second Truck Club
yes, it will build up heat, especially when the converter iis unlocked.
also the smaller diameter, (assuming it's a 10") is going to build up more heat than a stock 12".
Old Aug 8, 2006 | 04:48 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
its fine AP and Allen cant "tune" out the heat you gotta get a bigger cooler
Old Aug 8, 2006 | 05:18 AM
Quik's Avatar
5 year bitches!
its fine you should see some of the temps i see in DD of this heat around here. just be smart about it and you wont have any issues
i drive a 3800 9.5 converter daily if i can do it you can
TAPyvehc93
Sep 17, 2015 10:10 AM
kmcn47
Sep 17, 2015 01:12 AM
Rockrz
Sep 13, 2015 12:22 AM
GM1697
Sep 9, 2015 10:31 PM
GM1697
Sep 9, 2015 01:52 PM
