Outside air temp sensor as IAT sensor.
Old Sep 15, 2015 | 01:33 PM
TAPyvehc93's Avatar
Default Outside air temp sensor as IAT sensor.
I was just curious if anyone has converted their outside air temp sensor (the one mounted on the A-frame in the grill) into a IAT sensor. Couldn't I just cut and extended the wires and then install a sensor into my cold side piping? Then it would display on my dash?
Old Sep 16, 2015 | 10:31 AM
iamkeniff's Avatar
I am confused on you using a completely different style sensor as an IAT sensor
Why not just install an iat sensor and use the wiring from your maf?
Old Sep 16, 2015 | 10:48 PM
Suburbazine's Avatar
No, your idea will not work. GM uses dwell time on their AC and Mirror sensors. Simply put, if your intake temperature spikes or falls, the computer opts to adjust only 10% of the difference every 15 seconds. So if you go from 90* to 120*, it will take the mirror some 4 minutes to display the change.
Old Sep 17, 2015 | 12:10 AM
Wolftrk99's Avatar
If youre looking for a iat guage for your dash, in theory you could but it would still be off from what the ecm is seeing.... And if you wanna use it to tell the computer what the outside ambient temp is as iat then it will throw everything off the computer needs to see temp of the air going into the engine, and as previously stated they are different types of sensors,....id say get one from an impala or malibu or even old truck that has separate iat if thats what you wanna use for a guage and want ut to read accurately!!!!
Old Sep 17, 2015 | 10:10 AM
TAPyvehc93's Avatar
Okay, thanks guys!
lucas287
31
Jan 12, 2021 06:18 AM
ullose272
Aug 5, 2016 02:05 PM
GMCtrk
Dec 18, 2015 04:47 PM
GRRR65GTO
Aug 17, 2015 11:33 PM
Suburban2500
Jul 14, 2015 02:10 AM
