temp increase after new stall??
is it normal to see a trans temp increase after a converter swap???
I went from a 2800 to a 3200 stall, before temps would hang from 170-180 now its more like 190-200degrees??? I know the weather is hot down here so that does not help..... I have a small tranny cooler, I think I will be going with a bigger one...
How do I change this text
If the converter is not locking it will be way hotter......
in town it will be hoter, but at highway it should be about the same (lock all the time) maybe a a little bit hotter but not much..
do you know what GVW your trans cooler is rated to. i have a "3200" ~3400 stall with a 20-22000 GVW cooler. my temps quickly rise to about 150, slowly to about 180 and usually max out right before 195 if im doing ALOT of stop and go driving but those temps arent bad. im looking into a transcooler from OPT for 51.99 30000 GVW. comes with installation kit too, PM if you want the link.
its fine you should see some of the temps i see in DD of this heat around here. just be smart about it and you wont have any issues
i drive a 3800 9.5 converter daily if i can do it you can
TAPyvehc93
Sep 17, 2015 10:10 AM
GM1697
Sep 9, 2015 01:52 PM
