Sent my 4L60E to TransBuilderGuy
Old Oct 24, 2018 | 08:46 AM
  #241
someotherguy's Avatar
Richard
Old Nov 6, 2018 | 08:57 AM
  #242
Nealy_16's Avatar
Originally Posted by Choda
Update. The truck has been rocking for a while but was stuck in a body shop for 4 months. ARG. Once I got it back from the body shop I went racing. Busted out a 11.7 with a 1.7 60' in 4x4. Consistently running 7.5 in the 93 mph range. I noticed the trans temp getting warm on drives to work and around with the family, then the converter surging in and out of lockup. some days it was fine, some it surged, some it wouldn't lock. I have my tuner plug in and verify it was not electronic and the lockup was being engaged 100%.
A bit worried, I talked to Robert about it. He said i probably smoked the converter. It was a mild converter to begin with and im making way more power that we originally talked about. My tuner agreed. I ordered the PI vig 3000 multi disk. While waiting for it to come in, I started pulling the trans for a converter swap. I pulled the drain plug and it was COVERED in metal. Worse than ever before. I talked to Robert and sent him the unit for a total inspection and upgrade the 3/4 clutch set to the new th350 clutch unit.
Hes got the unit 9/20 and has been working on it.
I have a 08 Silverado with a mild built 4l60e and it has a 3200 FTI converter in it and I'm dealing with the same surge problem. Sometimes it wont lock up, sometimes it surges in and out of lock up as well. Does that mean the converter is going out?
Old Nov 6, 2018 | 04:48 PM
  #243
TXsilverado's Avatar
Originally Posted by Fast355
You do realize I am spraying 150 hp into a 6" rod 355 with 200cc aluminum heads and a 215/224 @ .050 roller cam with .578/.578" lift from the 1.7 rockers. On engine alone I am making about 425 HP at the flywheel. Make about 575 crank on spray. I don't spray while towing, but I have sprayed the thing just playing around for the hell of it. That engine sees 6,200 rpm multiple times daily at WOT.
My 2nd 4L80E is behind a L18 8.1 with the 420 HP mercruiser cam in my 1999 Tahoe. I also spray 150 shot into it. Makes about the same HP as the small block but ALOT more torque.
Do you plan on fabricating a stolen dyno sheet to prove your claims? Asking for a friend
Old Nov 6, 2018 | 07:19 PM
  #244
madmann26's Avatar
Don't feed the troll, please.
Old Nov 7, 2018 | 02:00 PM
  #245
Choda's Avatar
I have been talking with the new owner of the truck - Kuntryquest.
He and the local trans shop found a lot of issues with the unit and decided it best to bail on it all together and start from scratch. I believe they reused some of the hard parts that were still in good working order and it was built to RPM Transmissions spec sheet. New case, VB, some hard parts and same converter. The truck is now driving great, fluid temp, converter lockup, towing.... everything is good. Im glad to see its finally working after the years of crap i went through and thousands of dollars PLUS the new owner's time, money and frustration.
cliff notes to 25 pages of thread. I should have listened to the masses and went 80 years ago and I do not recommend Transbuilderguy.
Old Nov 7, 2018 | 02:23 PM
  #246
1FastBrick's Avatar
Custm2500's Rude Friend
I had a feeling things would turn out this way... Glad it's done and over with.
Old Nov 7, 2018 | 02:50 PM
  #247
wretched73's Avatar
Don't be too hard on yourself. Sometimes you need to learn the hard way.
Old Jan 5, 2019 | 06:06 PM
  #248
Mark Johnson's Avatar
So that's what ultimately happened with that endless 4L60 build. Glad I just went with the whole Gen 5 truck.............
Old Jan 6, 2019 | 09:54 AM
  #249
madmann26's Avatar
I did the same with a local builder and a reputable level 7 trans.
In the end, it doesn’t matter what you do. Go to an 80e and never look back.
I’ve had my 80e swap almost a year now and I have had zero issues out of it. Zero.
Old Jan 8, 2019 | 07:38 AM
  #250
Wow- Level 7 even, never would've believed it...………...
