Question on tire rubbing on a 2/4 drop?
Old Jan 15, 2008 | 01:28 AM
chevyguy7802's Avatar
Default Question on tire rubbing on a 2/4 drop?
Im really thinking about lowering my 06' 2/4 drop and would be driving on my stock 17's for quite awhile till i got the funds for the 20's,am i going to have any bottoming out or tire rubbing issues on the front? Im pretty sure my tire size now is 245/70/17........any help would be greatly appreciated
Old Jan 15, 2008 | 07:38 AM
jkwalkercchs's Avatar
i had my avalanche slammed 3in in the front and it never rubbed with 20s
Old Jan 15, 2008 | 08:24 AM
sickREDsierra's Avatar
i get rub on my 20's, but only when turning sharp at slow speeds..... they rub on the inside somehow. my brother has 22's on his and doesnt rub? who knows?
i run 285/50 20's i would think a little bit narrower tire would not rub 275/55 20 ?
Old Jan 15, 2008 | 12:01 PM
StrokerAce03's Avatar
275/55 would rub worse; its taller.
You should be fine with 245/70 17's and a 2/4. I've seen some with a 4/6 and that tire size and no problems. The stock wheels tuck very nicely and the tire isn't wide enough to cause problems.
Old Jan 15, 2008 | 01:35 PM
no ****. i said mine rubs on the sides, not the top of the tire.
a narrow tire wouldnt do that. i have plenty of clearance top to bottom.
Old Jan 15, 2008 | 02:40 PM
Thanks for the reply....im going to be dropping it soon i think im going with spindles and hotchkis 4'' drop leafs.......
Old Jan 15, 2008 | 08:01 PM
I run 275/60/17 on a hotchkis 2/4 and I've never rubbed
Old Jan 15, 2008 | 10:44 PM
I run 275/40/20 with a 4/6. 28.75" tall tire I had to roll the rear fenders and it rubs of I hit a hard bump. Otherwise no problems. See sig.
Old Jan 16, 2008 | 12:23 AM
00Silv4.8's Avatar
a 275/55 is not even a half inch taller than a 285/55. so if ur having side to side issues go to a 265 or 255, I had 255s on my truck with the SS wheels but hated how skinny they were so good luck.
thunder550
Oct 8, 2015 04:53 PM
USMCvet0311
Aug 1, 2015 07:45 AM
projectnightcrawler
Jul 19, 2015 11:30 PM
KleanKustoms
Jul 18, 2015 10:08 PM
