Official A4 to M6 (T-56) Thread!
Old Oct 15, 2010 | 04:14 PM
  #851
xx_ED_xx's Avatar
Do we have a driveshaft length, I know it was mentioned an auto one would work if you had a 5 speed. But I hate to go buy one to find out it was the wrong length.
Old Oct 15, 2010 | 10:42 PM
  #852
PathfinderJr's Avatar
I had a 5-spd and picked up a rcsb auto driveshaft and it is doing just fine.
Old Oct 15, 2010 | 10:52 PM
  #853
xx_ED_xx's Avatar
Can you go measure its length from u joint cup to u joint cup?
Old Oct 16, 2010 | 08:04 AM
  #854
_zebra's Avatar
makes children cry
Originally Posted by regcabls6
Clutch pedal is sticking to floor when shifting at wot. Has anybody drilled there master cylinder?
Originally Posted by Ketis
i looked at my 03 master and there appeared to not be anything to drill out.
that's because you don't drill out the master cylinder.
the restriction is in the actual clutch line. pop the roll pin out & disconnect that end of the hose & there's a little plastic restrictor about an inch in.
just look up "drill mod" & find something that talks about f-bodies. that'll typically pull up a writeup with pictures.
Old Oct 16, 2010 | 09:29 AM
  #855
Sure thing. I'm hoping to have a chance to change the oil tomorrow, so while i'm under there I'll slap a tape on the driveshaft.
Old Oct 16, 2010 | 09:30 AM
  #856
xx_ED_xx's Avatar
I appreciate it
Old Oct 21, 2010 | 05:42 AM
  #857
johnboy122's Avatar
I'm undergoing the swap myself. I went with the m12 t56, ls7 clutch, ls2 Z06 flywheel and its goin behind a BB4.8 lol. Is there a final solution to the wiring problems or is rafaedails diagram the final verdict? Im going to have nelson performance do the computer flash to remove the tables and follow the diagram in this post is this all I need to? I got a little confused once I read the post about keeping the auto tune.
Old Oct 21, 2010 | 07:44 AM
  #858
Ketis's Avatar
on my master, the line that comes off of it has a 90 degree elbow. so unless you are talkin about at the slave, then i cant do that one
i have either an 03 or 04 master btw
Old Oct 21, 2010 | 03:46 PM
  #859
johnboy122's Avatar
I just called nelson performance and they said I don't need a tune, am I missing something here? And thanks for the great info guys.
Old Oct 21, 2010 | 09:35 PM
  #860
I appreciate it
Yeah, sorry, I never got around to that oil change. We'll see about this weekend coming up.
