Nnbs 4x4 4l80 swap?
Old Jan 26, 2012 | 07:24 AM
scooter k's Avatar
Default Nnbs 4x4 4l80 swap?
What are you guys doing on the GMT900 NNBS trucks to swap over to the
4L80 trans? RPM says you need to change out the transfer case. Phoenix transmission makes a custom output shaft to fit the transfer case with a customer adapter also. You have to spend a lot more money but he makes it all from the converter, trans, with bell housing cover, and free shipping.
Old Jan 26, 2012 | 08:27 AM
Atomic's Avatar
I have a gauge for that
Not sure if its any different for 07+ but on the 99-07 you only need to change the input shaft on the tcase. Costs about $120 online.
Old Jan 26, 2012 | 08:40 AM
scooter k's Avatar
I did see that with the older trucks. I didn't know for sure how this works with the newer transfer case.
Old Jan 28, 2012 | 11:20 AM
scooter k's Avatar
I ended up getting everything from Phoenix transmission. He makes the billet output shaft to fit my transfer case. Comes with everything from dipstick and tube to dust cover. How far does the crossmember need to move back on a 4wd??
Old Jan 28, 2012 | 01:18 PM
Atomic's Avatar
2.5 inches
Old Jan 28, 2012 | 03:12 PM
scooter k's Avatar
2.5 inches
I have a lot of down time right now to do this before the engine and trans show up. If you are sure I will cut it and weld it up.
Old Jan 28, 2012 | 03:35 PM
smokeshow's Avatar
Mod with training wheels
Did you get my PM? I measured 2 5/8" this morning. Just welded a piece of angle iron onto the crossmember, worked fine. Even if you are off a little bit it doesn't matter because the hole needs to be slotted anyway.
Old Jan 28, 2012 | 03:37 PM
scooter k's Avatar
Yes I got it. I just thought you were referring to 2wd and 4wd was different.
Sorry
Old Jan 28, 2012 | 11:14 PM
pewterliftedz's Avatar
i was about to say that no one at this time has an input for the NNBS transfer case's.
when i was looking at the 80e swap, the only solution i could come up with was switching outputs on the 80e. glad u got it figured out.
Old Jan 29, 2012 | 05:11 PM
scooter k's Avatar
Had my friend, Rich, cut the crossmember and tack weld it 2.5" back. Once I confirm it fits he'll finish it up. Should look really good. He tig welds everything.
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
SloSVO
Aug 11, 2015 07:33 PM
GM-only
Jul 19, 2015 10:48 PM
vmaxpro
Jul 17, 2015 07:24 AM
Nimoryan
Jul 5, 2015 03:50 PM
