chevy lean revisited plz help
ok ive seen 100's of threads on the chevy lean my LF sits lower than right side, have heard of everyone talking about a gm tsb about installing and isolator under the coil spring, i need the gm part number for that isolator all i could find at gm i work at dealer next door is a tsb for suspension lean is a spacer for the rear, is there one for the front, truck is 2wd rcsb, any help would be greatly appreciated thanks
It should, if not you could always get a drop shackle and put it in the 1 inch setting. Clamping the overload got rid of my lean in the rear but not the front.
I have 2" drop shackles right now, I don't think they had a 1" setting, but I could probably drill one. A 2/4 drop is in my very near future and would like to eliminate the lean at the same time. I'm planning on spindles up front, and 2" shackles plus 2" hangers out back. It will probably end up more like a 2/4 on the right side and 1/3 on the left side
