Nbs bolt-in notch questions.
What have y'all used to cut the frame for notches on your trucks? Would a 10 amp dewalt angle grinder with a cutoff wheel suffice? After my ordeal with hanger rivets, I don't think my air compressor is fit for metal working duties. Enough scfm and max pressure, but it only kicks back on at 50 or so psi. No bueno.
I know to avoid the djm flat plate notches. Has anyone had durability issues with a mcgaughy's notch? The belltech sandwich notch should be bomb proof, but is $$$. Also, how much travel do you gain over a stock frame. I already have pancake bump stops. Getting 2" or so extra won't really cut it for my application. Thanks.
-Andrew Kitchens
-Andrew Kitchens
