Nbs bolt-in notch questions.
Old Apr 25, 2012 | 12:23 PM
wheeliE-maxx's Avatar
Default Nbs bolt-in notch questions.
What have y'all used to cut the frame for notches on your trucks? Would a 10 amp dewalt angle grinder with a cutoff wheel suffice? After my ordeal with hanger rivets, I don't think my air compressor is fit for metal working duties. Enough scfm and max pressure, but it only kicks back on at 50 or so psi. No bueno.
I know to avoid the djm flat plate notches. Has anyone had durability issues with a mcgaughy's notch? The belltech sandwich notch should be bomb proof, but is $$$. Also, how much travel do you gain over a stock frame. I already have pancake bump stops. Getting 2" or so extra won't really cut it for my application. Thanks.
-Andrew Kitchens
Old Apr 25, 2012 | 04:19 PM
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
I just put a belltech bolt in notch in my truck and used a 4-inch angle grinder worked awesome you'll also need a drill to 1/2 chuck would be best
Old Apr 25, 2012 | 05:25 PM
rkwhite61's Avatar
I too used an angle grinder with a cutting wheel for my belltech notch install.
Old Apr 25, 2012 | 06:35 PM
lglowe's Avatar
Djm notch for me. Good notch with great fit. I used a sawzall.
Old Apr 25, 2012 | 06:47 PM
2 tone 02's Avatar
Pick up a mcgaughys or belltech. Djm are junk. Be sure to drill the corners before you cut!
Old Apr 25, 2012 | 08:12 PM
Sawzall or angle grinder, I can do that. Any measurements for travel increase?
Old Apr 25, 2012 | 08:50 PM
2 tone 02's Avatar
You're going to gain the depth of the notch so like 2-3 inches
Old Apr 26, 2012 | 12:35 AM
1siktoy's Avatar
I used a sawzall mcg notch
Old Apr 26, 2012 | 04:18 PM
lglowe's Avatar
May I ask what is " junk" about the djm notch.
Old Apr 27, 2012 | 12:44 AM
heres my belltech vers a DJM docent take a brain surgeon to figure out which one is better
