Is my tranny going bad?
Old Nov 28, 2008 | 05:12 PM
ChevyTruck's Avatar
something else
Unhappy Is my tranny going bad?
I need some input.
When I step on the gas and go WOT it revs then it feals like it goes into gear. When I do a WOT it revs to 6grand and has a pause in the shift like it revs out of 1 and then into 2 gear.
I have a weatley tune and it has never done that untill about yesterday. What to you guys think it might be, is my tranny is about to go or is my tourqe converter about to go?
Thanks RJ
Old Nov 28, 2008 | 05:26 PM
Mangled03gmc's Avatar
Baltimore Whore
J take a look at your trans fluid, give it the ole sniffer test.. That will tell ya a lil right there..
John
Old Nov 28, 2008 | 05:27 PM
ChevyTruck's Avatar
something else
Well what shoud it smell like, if it's bad?
Old Nov 28, 2008 | 05:33 PM
Baltimore Whore
It will have a dark color, not the redish color like it posed to, will smell burnt.. You will no.. If ya can't get a grasp from that take and smell some out of a quart jug, comp to what yours smells like
John
Old Nov 28, 2008 | 05:35 PM
ChevyTruck's Avatar
something else
Cool I will take a look at it tomorrow, I have to drop the oil pan and change the oil dip stick tube, so I will dran a little bit out tomorrow.
Old Nov 28, 2008 | 05:37 PM
Baltimore Whore
I don't think you have to drop the pan to swap sticks
John
Old Nov 28, 2008 | 05:42 PM
ChevyTruck's Avatar
something else
Yea I do, I broke the tube in the block a few months back. I have a screw that is jb welded in the broken tube. I have been putting it off for sometime.... I have some chitty luck.
Old Nov 28, 2008 | 07:19 PM
viciousknid's Avatar
Where's the Beef?
You could probably just pull it out with some needle nose pliers through the drain hole, that's what I did.
Old Nov 28, 2008 | 08:22 PM
ChevyTruck's Avatar
something else
I would love to but it will not budge at all
friking oil pan gasket was 50 bucks
Old Nov 28, 2008 | 08:34 PM
venomhp's Avatar
Id also replace the filter while your right there, just me though
