Is my tranny going bad?
#52
They said that they installed a corvette servo 2 4? The orginal one was gone he said that he has never seen anything like that before. I did a good job tearing it up. Haha. I will get it in the morning.
#55
#57
Well thay found something wrong with the front differential seals thay are leaking, that is covered under warranty also. I did not even know it was leaking so maybe its a good thing that its in there. I should get it back tomorrow morning, well it will be done this afternoon but I will be at work when its done.
#58
Well I have the truck back.
Is there a "break in" milage?
Below is from the Invoice from the dealership.
Trans slipping 1-2 shift-will not pick up speed when merging into traffic on acceleration- check and report
Cause: Drum scored, Clutches burned, Seals leaking
K 7231 Housing and deum assembly, Reverse input R&R or replace
Well all that was done was,
QTY Part Number
1 24242395 F-gasket
1 24236378 GSKT kit
1 24208576 FLTR kit
1 24232236 Band
1 8681295 F-housing
1 24238603 Plate kit
1 24241783 Plate
14 ATF Fluid
1 8642079 Piston
1 8673039 Housing
F1447 Seals, Front Differential Output Shaft
Front both replaced
2 15801507 Seal
Thats all for now.
Thank you everyone that chimed in for the advice.
RJ
QTY Part Number
1 24242395 F-gasket
1 24236378 GSKT kit
1 24208576 FLTR kit
1 24232236 Band
1 8681295 F-housing
1 24241783 Plate
14 ATF Fluid
1 8642079 Piston
1 8673039 Housing
Front both replaced
2 15801507 Seal
Thats all for now.
RJ
#60
Thanks. The shifts are a lot more firm.
I was playing with a guy from work with a acura 3.2, i was right on him till 98.... Then she just stopped going, I dont have the tune on.
