how many miles to break in a new gear install?
Old May 28, 2005 | 12:09 PM
02chevyracing's Avatar
14 Second Truck Club
Default how many miles to break in a new gear install?
im about to get a posi and 373 installed, but i want to go to the track and see what this bad boy will run. so i was wondering what is a good amount of miles to put on the rear before getting on it pretty hard.
Old May 28, 2005 | 12:30 PM
BlownChevy's Avatar
blownerator
25 Year Member
There are going to be many opinions on this. I have always run them through a few heat cycles (4 or 5) with out any serious WOT runs. After that, it was open season.
Old May 28, 2005 | 12:55 PM
FILE's Avatar
The rule of thumb is 500 with several heat cycles. I only took easy on my gear for the first 100 miles then I beat on them and no problems so far after 30+k miles.
Old May 28, 2005 | 02:15 PM
BLACKND's Avatar
Yeah, different shops say different things. I did a long single heat cycle at slower speeds, cause I was a ways away from home. Then let cool down completely and did a seperate 20-30 minute heat cycle twice. Then I beat on em. 20,000 miles later still doing good.
Old May 29, 2005 | 12:21 AM
I did the same swap w/ Richmond gears and Eaton, took it easy on mine for about.........30 miles. Then sprayed a little happy juice to it. Has been working great for about 5-6k miles w/no problem.
Old May 29, 2005 | 02:21 AM
negativeswitches's Avatar
if you set them up right it shouldent be an issue just get a few miles on them bafo you get happy
Old May 29, 2005 | 11:53 AM
samdogmx's Avatar
8 Second Club
drive around for about 15 min, stop, cool off, drive another 15 min, enjoy....
recheck backlash at about 200-300 miles
Old May 29, 2005 | 04:29 PM
CAMMIN03''s Avatar
Banned
I had strange 4.10's put in and ran about 50 miles on it... then nailed the **** iout of it all night.... and 24000 miles later still no problems...
Just make sure you get the Master Installation kit that comes with the pinion and side bearings....
Good luck with it
Old May 29, 2005 | 06:57 PM
It is important with new bearings to get 3-4 heat cycles in them. New bearings generate a lot of heat, so you need to wear those in. At least 15 minutes of run time followed by a long cool down.
Old May 29, 2005 | 08:17 PM
onyx's Avatar
also, make sure to change out the fluid after your "break-in" period.
Choda
Jan 22, 2026 02:03 PM
ferrellrooster
Mar 6, 2025 03:22 PM
LCHEE
Oct 24, 2020 04:10 PM
lxcoupe
Jul 21, 2015 02:12 AM
Gadgetized
Jul 7, 2015 04:40 PM
