High Stall TC questions
Yes, I read all the threads I could find with search, none of them really answered this question though
I'm looking to put a 3600-4000 stall PI converter in my truck and was wondering...would it hold up to towing 2 ton loads occasionally? If I get a multi-disc lockup, is it strong enough to hold if I have the tow tune set to engage it at 40-70MPH in 3rd or OD? I have the biggest Perma-Cool HD transmission cooler on the market.
The 2200 stall tows, well, ok at best. At medium speeds like 35-50 I can't get the truck and trailer off it's butt and moving because the powerband is out of reach. I do love the extra bit of power off the line (over stock) with this TC and I want more. I have 3.73 gears and a change is not possible right now.
EPS Dyno Tune
Stock 862 heads ported, ground & milled 30 thousandths
Comp Cams 218/222 114LSA +4 .600 lift
TEA Dual Gold Valve springs + pushrods
GM Performance Timing Chain set
Oil Pump pressure mod
No Cats
Level 3 4L60E w/ Precision Industries 2200 stall
No headers, 3.73 gears, can't do a gear swap at the moment due to 4x4.
Would I be better off stopping with a 3000 stall then? Once I get it up over 3500 it makes power. I like the loose feeling and mileage can't get any worse unless I drill a hole in the gas tank.
I only put about 500 towing miles a year on the truck. Everything else is just hauling ***.
No Cats
I just got back from a 1000 mile trip towing a 7000lb trailer. The converter worked great on the highway but is kinda the ***** getting going in 1st and 2nd. I wouldn't want to go any higher than my 2600 and was wishing for my stock stall more than once.
Mine got going better from a stop with an extra 800 stall rpm.
When you had your engine built did you have it dyno tuned? I would be interested to know what the torque curve looks like. Also, if your cam is installed +4* that may be robbing you bottom end torque that would be useful in towing situations.
Based on your comments and your combination... I would suggest that you're going to be looking for a converter that stalls around 2,800 - 3,200 rpm and has multiple discs that can manage the loads you pull long term.
g
g
g
g
I did install the cam to +4* as that is what was milled into the cam and I used a non-adjustable timing set this time around. As far as torque goes, I don't know if I'm actually losing any low range over the stock cam. A new dyno run is obviously a must-have.
PS: Yes, I did everything on the engine except the machining work myself- at least I figured out what not to do on this build!
