High Stall TC questions
Old Aug 5, 2011 | 06:36 PM
Suburbazine's Avatar
Default High Stall TC questions
Yes, I read all the threads I could find with search, none of them really answered this question though
I'm looking to put a 3600-4000 stall PI converter in my truck and was wondering...would it hold up to towing 2 ton loads occasionally? If I get a multi-disc lockup, is it strong enough to hold if I have the tow tune set to engage it at 40-70MPH in 3rd or OD? I have the biggest Perma-Cool HD transmission cooler on the market.
The 2200 stall tows, well, ok at best. At medium speeds like 35-50 I can't get the truck and trailer off it's butt and moving because the powerband is out of reach. I do love the extra bit of power off the line (over stock) with this TC and I want more. I have 3.73 gears and a change is not possible right now.
Old Aug 5, 2011 | 06:56 PM
Rhino79's Avatar
9 Second Club
I would say it will not last long, nor will a converter that loose even get you moving more than likely.
Old Aug 5, 2011 | 06:57 PM
andrew383's Avatar
traveling mod
Higher stall will not help towing..
What gears do you have?? More than likely a gear change would help..Also i dont see headers listed.. What are your full mods??
Old Aug 5, 2011 | 07:04 PM
EPS Dyno Tune
Stock 862 heads ported, ground & milled 30 thousandths
Comp Cams 218/222 114LSA +4 .600 lift
TEA Dual Gold Valve springs + pushrods
GM Performance Timing Chain set
Oil Pump pressure mod
No Cats
Level 3 4L60E w/ Precision Industries 2200 stall
No headers, 3.73 gears, can't do a gear swap at the moment due to 4x4.
Would I be better off stopping with a 3000 stall then? Once I get it up over 3500 it makes power. I like the loose feeling and mileage can't get any worse unless I drill a hole in the gas tank.
I only put about 500 towing miles a year on the truck. Everything else is just hauling ***.
Old Aug 5, 2011 | 08:21 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Throw a radix on top of it and have fun. Seriously.
Old Aug 5, 2011 | 09:58 PM
Great. Now you made me drool on my laptop while pondering the idea.
Old Aug 5, 2011 | 10:52 PM
swift700's Avatar
I just got back from a 1000 mile trip towing a 7000lb trailer. The converter worked great on the highway but is kinda the ***** getting going in 1st and 2nd. I wouldn't want to go any higher than my 2600 and was wishing for my stock stall more than once.
Old Aug 6, 2011 | 01:29 AM
Is it because you have to keep your foot in it or because it slips too much? Do you run out to the rev limiter too easily? I was figuring more stall = more torque. Am I missing something?
Mine got going better from a stop with an extra 800 stall rpm.
Old Aug 6, 2011 | 01:03 PM
Gilbert@Ace Racing's Avatar
FormerVendor
When you had your engine built did you have it dyno tuned? I would be interested to know what the torque curve looks like. Also, if your cam is installed +4* that may be robbing you bottom end torque that would be useful in towing situations.
Based on your comments and your combination... I would suggest that you're going to be looking for a converter that stalls around 2,800 - 3,200 rpm and has multiple discs that can manage the loads you pull long term.
g
Old Aug 6, 2011 | 01:29 PM
g
Yes, it was dyno tuned. I don't have exact dyno numbers (or a graph) on the current tune yet, the last pull I made was with bad spark plugs and a bad timing chain. It only laid down 263RWHP and 245ish torque (stock was 245RWHP and 220 torque). All the tuning since has been touch up work after I fixed the problems. I'll see if I can get Geoff at EPS to send me the dyno graphs.
I did install the cam to +4* as that is what was milled into the cam and I used a non-adjustable timing set this time around. As far as torque goes, I don't know if I'm actually losing any low range over the stock cam. A new dyno run is obviously a must-have.
PS: Yes, I did everything on the engine except the machining work myself- at least I figured out what not to do on this build!
