help with the 4l60e
Old Apr 29, 2010 | 10:03 PM
knuckles's Avatar
Default help with the 4l60e
I got a 2006 trans that I bought to rebuild to replace the bad trans in my truck.I put new clutches steels band. I but the alto wide band and 3 4 clutch pack. And put the hd2 shift kit in. I put it in the truck with a tt2600. I don't have 1st or 4th in d. But can put in 1st manualy. I put new a and b silinoids to try and fix but didn't work. What might I look for? And will the 2006 work in a 2000?
Old Apr 29, 2010 | 10:15 PM
FLT's Avatar
FLT
FormerVendor
Look at your new steel 1-2 shift valve and make sure the gold ball/green spring are in the right positions. Any codes?
Old Apr 29, 2010 | 10:18 PM
knuckles's Avatar
No codes. I think I might have forgot the spring. I goes spring ball silinoid right
Old Apr 29, 2010 | 10:25 PM
FLT's Avatar
FLT
FormerVendor
No the ball goes in the valve first and then the little green spring. Followed by the solenoid and clip. Vince
Old Apr 29, 2010 | 10:36 PM
knuckles's Avatar
Thank you I think I might have forgot the green spring. I knew you would know what the problem would be. Thank you
Old Apr 29, 2010 | 10:49 PM
built408's Avatar
Ya, I would double check the spring/checkball placement. And you did reuse the original white spring also?
Maybe Vince can post up some of his cute pictures.......
Old Apr 29, 2010 | 11:00 PM
stevenc's Avatar
Yeah. My monies on the spring & checkball. I made this mistake before
Old Apr 29, 2010 | 11:33 PM
knuckles's Avatar
Yeah I looked at the instructions and ether the spring and ball are backwards or the spring is in a dark corner of the shop haha. That is what I get for staying up till 2am working on a trans.
Old Apr 30, 2010 | 01:09 PM
knuckles's Avatar
Yep had the ball and spring backwards. Vince you are the man. Knew what it was right off the bat. Thank you vince
Old Apr 30, 2010 | 09:26 PM
FLT's Avatar
FLT
FormerVendor
Glad to be of service. Good luck with the new combo. Vince
Wolftrk99
Dec 3, 2015 08:12 PM
Wolftrk99
Oct 2, 2015 08:17 AM
jamesm32
Sep 24, 2015 11:49 AM
RONIN LSX
Sep 19, 2015 05:33 PM
