help with the 4l60e
I got a 2006 trans that I bought to rebuild to replace the bad trans in my truck.I put new clutches steels band. I but the alto wide band and 3 4 clutch pack. And put the hd2 shift kit in. I put it in the truck with a tt2600. I don't have 1st or 4th in d. But can put in 1st manualy. I put new a and b silinoids to try and fix but didn't work. What might I look for? And will the 2006 work in a 2000?
Look at your new steel 1-2 shift valve and make sure the gold ball/green spring are in the right positions. Any codes?
No codes. I think I might have forgot the spring. I goes spring ball silinoid right
No the ball goes in the valve first and then the little green spring. Followed by the solenoid and clip. Vince
Thank you I think I might have forgot the green spring. I knew you would know what the problem would be. Thank you
Ya, I would double check the spring/checkball placement. And you did reuse the original white spring also?
Maybe Vince can post up some of his cute pictures.......:wavey: |
Yeah. My monies on the spring & checkball. I made this mistake before :bang:
Yeah I looked at the instructions and ether the spring and ball are backwards or the spring is in a dark corner of the shop haha. That is what I get for staying up till 2am working on a trans.
Yep had the ball and spring backwards. Vince you are the man. Knew what it was right off the bat. Thank you vince
Glad to be of service. Good luck with the new combo.:nod: Vince
