G80 vs TT
Old Sep 1, 2011 | 09:53 AM
BrutalSierra's Avatar
Default G80 vs TT
I know everyones answer is going to be True-Trac
But is the g80 really that bad? I'll be ordering 4.11's for my truck soon and wanted to know if you think the G80 would last behind 400rwhp?
It's my DD and was concerned about changes in drivability. Any insight would be nice.
Old Sep 1, 2011 | 10:05 AM
TX Tahoe Z71's Avatar
It might survive, it might not. I still have my G80 in and am pushing 450/500ish, but I have a TT sitting under my bed that I have been meaning to install.
My decision process went like this: Will the G80 take a crap and kill my ring and pinion because I am putting too much stress on it? maybe, others have been fine but still, others making less power have not been so lucky. Will it take out my non-built transmission at the same time? Less likely but still possible. Is it worth $400+$100 for the truetrac and install kit for me to not have to worry about being stranded ($80 tow truck), having to replace the differential ($400+$100) AND replace my ring and pinion (haven't priced them, but $200ish)? Yes, to me, it's worth the $500.
Old Sep 1, 2011 | 11:09 AM
Are the G80's different in the 10bolt /14bolt?
being i have the 6.2, my truck has the 14bolt. And seems to feel strong but then again i do see your logic!
Old Sep 1, 2011 | 11:29 AM
I would only be guessing about the reliability of the G80 in the 14 bolts but I would imagine they would take more abuse than a 10 bolt one. Hopefully someone with more knowledge about them will chime in.
Old Sep 1, 2011 | 04:40 PM
black4.8's Avatar
tru trac is very smooth and as strong as they come. hated my g80, always making a clunking noise. don't know the tt is even back there.
Old Sep 2, 2011 | 04:42 AM
06Sierra2's Avatar
this was pretty much my exact thought process as well. why risk trying to make a weak link work after you install aftermarket gears and risk having to replace the differential and possibly gears again
Old Sep 2, 2011 | 05:21 AM
iamkeniff's Avatar
The TBSS runs a 14bolt with a G80 and not everyone swaps them out but then you have to take in the fact that the TBSS is lighter so thats less moving mass upon take off. The 14bolt is stronger but i dont know how strong it will be. I know under a 5.3/60e my g80 couldnt hold stock power on a good launch. I do have a 10 bolt, not a 14 bolt. I would have to agree with TX Tahoe, just save up for it or change it now vs replacing a 200.00 set of gears along with a master install kit and labor if you arent the one doing the install.
Old Sep 2, 2011 | 01:12 PM
chpspecial's Avatar
FYI, The TBSS g80 uses a clutch LSD, vs. Trucks G80 that uses an inertia locker g80
Old Sep 2, 2011 | 01:14 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
If you plan on tire-spin, especially around corners, the G80 will not live long. It's lifespan will mostly depend on how you drive.
Corvette454l88
Sep 1, 2016 01:24 AM
97aztecgt
Aug 13, 2015 02:11 PM
vmaxpro
Aug 8, 2015 10:49 PM
02sierraz71_5.3
Jan 19, 2005 03:04 PM
1TRUESS
Feb 14, 2003 02:52 PM
