DJM 4/6 Drop kit?
Old Apr 20, 2007 | 12:58 PM
Dirty 30's Avatar
LS1Tech Whore
Default DJM 4/6 Drop kit?
Where's the cheapest place online to order a DJM 4/6 drop kit, LCA's and Flip kit?
Old Apr 20, 2007 | 01:21 PM
Dirty 30's Avatar
LS1Tech Whore
...and what exactly else do I need to complete the installation???
Old Apr 20, 2007 | 03:35 PM
02BlueStepside's Avatar
When I was looking, stylin concepts had the best price. Check a few forums though, you might get lucky and get a used kit much cheaper.
Other than the kit, you will need rear shocks. You could just go ahead and get a full set if you want, but the stockers will work up front.
Old Apr 21, 2007 | 02:22 AM
Dirty 30's Avatar
LS1Tech Whore
thanks! what about this tie rod flip kit thingy i saw on there??? and some other stuff?
Old Apr 21, 2007 | 08:38 AM
The tie rod flip kit is to help eliminate bumpsteer. Personally I haven't noticed it to be a problem so I never did it. Eitherway though, its not neccessary. Can't think of anything else you need, what have you seen?
Old Apr 21, 2007 | 11:28 PM
Dirty 30's Avatar
LS1Tech Whore
something about keys and bumpstop and i guess i dont know what im talking about lol
Thanks a lot tho! Im about to order the kit.
Old Apr 22, 2007 | 08:55 PM
Sounds like some of the stuff some of the 4wd guys need to get low. If you are 2wd, I assume you are since you are looking at the djm 4/6 kit, you don't need that stuff. The kit and some rear shocks is all you NEED.
Old Apr 23, 2007 | 05:11 PM
LS1TRUCKGUY's Avatar
as 02blue stated, you just need the kit, and shocks. kit comes with everything needed. i also have not noticed any bumpsteer or abnormal tire wear.
Old Apr 23, 2007 | 06:21 PM
Dirty 30's Avatar
LS1Tech Whore
does it bottom out? and could I use a stock tahoe rear sway bar with the 4/6 kit?
thanks again
Old Apr 23, 2007 | 08:21 PM
405hpta's Avatar
Banned
if you are deeply into drag racing then I wouldn't go 4/6
