DJM 4/6 Drop kit?
When I was looking, stylin concepts had the best price. Check a few forums though, you might get lucky and get a used kit much cheaper.
Other than the kit, you will need rear shocks. You could just go ahead and get a full set if you want, but the stockers will work up front.
The tie rod flip kit is to help eliminate bumpsteer. Personally I haven't noticed it to be a problem so I never did it. Eitherway though, its not neccessary. Can't think of anything else you need, what have you seen?
Sounds like some of the stuff some of the 4wd guys need to get low. If you are 2wd, I assume you are since you are looking at the djm 4/6 kit, you don't need that stuff. The kit and some rear shocks is all you NEED.
