Ditched the Torsion Bars for Coilovers on the HD
#123
#124
Agreed !
Are you planning on removing the torsion bar crossmember to ? I can see a weight savings there too.. Not sure if you're concerned about frame flexing if its removed or not ? (thinking out loud here-->) I guess you could devise some sort of tubular or boxed cross member to replace it an still have rigidity with an additional weight savings...
#126
I will probably remove the crossmember...I am not too concerned about flexing since there is another crossmember right behind it.
I went with 1000lb springs because I wanted very little front end movement for launching and also the range of travel is not very much. I went with a shorter spring than recommended so I could more easily select the ride height I wanted.
I will make a thread later this week when I get it installed.
#129
intriguing thread
quick question..
Would it not be beneficial to use a progressive rate spring in a coil over setup? I noticed you guys are all talking about fixed rate springs. I was under the impression that the main disadvantage of a torsion setup was the lack of progressive rate springs
quick question..
