Ditched the Torsion Bars for Coilovers on the HD
Old Mar 13, 2013 | 01:14 AM
  #111
AKlowriderZ71's Avatar
11 Second Hall Moniter
The upper brackets need to be welded in. Since you're gonna have to weld anyways, why not make your own brackets? There has to be somebody near you that can help.
There's really not very much to them. Some 3/16" plate is cheap.
Old Mar 13, 2013 | 11:00 AM
  #112
Koots's Avatar
I would have never thought that you could fit a coilover in these torsion bar trucks, without ditching the 4WD.
I now refuse to spend any money on the suspension of my truck until I can afford Fox emulsion coilovers.
Old Mar 19, 2013 | 08:28 PM
  #113
Tydriver's Avatar
Been following this for a while, just curious to see if anyone has actually tried the HD arms against the standard arms..
I'd like a reasonable option for installing coil-overs in the front, wondering if anyone has found a way to bypass the 'clevis' style required by the OEM setup pictured in this thread.
Anyone ? Anyone ??
Thanks in advance,
Old Mar 20, 2013 | 12:21 AM
  #114
Atomic's Avatar
I have a gauge for that
Ill let you know something next week
Old Mar 24, 2013 | 10:19 PM
  #115
dirtyyetsoclean's Avatar
i found a couple things that might help.
Coilovers for NBS Silverados
http://www.cachassisworks.com/whitep...ion_WP_WEB.pdf
im very curious to see if the 1500hd/2500 lower control arm fits on a regular 1500 4x4
does anyone know the individual wheel corner weights of our trucks?
Old Mar 24, 2013 | 10:26 PM
  #116
Atomic's Avatar
My truck had approximately 1450 on the fronts and 900 on the rears.
Old Mar 25, 2013 | 12:17 AM
  #117
any idea of the length of the stock front shock at ride height?
that length, (adjusted according to how much drop or lift you want) plus 40% for the ideal extended coilover length. and compressed coilover length should be 60% of the istalled shock length?? or what am i figuring wrong? lol that part doesnt sound right
Old Mar 25, 2013 | 11:34 AM
  #118
Koots's Avatar
According to NAPA here is their specs for 2500HD front shocks:
Compressed Length:10.25"
Extended length:15.125"
Travel Length:4.875"
Here are their specs for a GMT800 K1500 shock:
Compressed Length:10.875"
Extended length:15.375"
Travel Length:4.5
These seem to be about the same for all factory replacement shocks for each vehicle.
Old Mar 25, 2013 | 05:35 PM
  #119
well... thats much less room than i was hoping to have with dropping it on a stock LCA lol i was debating making a jig off a stock arm, and making a tubular arm with a lower eyelet mount, to fit a little bigger coilover
MN roads arent very forgiving
my truck currently has a 6 inch lift so im kinda flying blind. if im not mistakin, my factory torsion bar crossmember brackets are cut off the frame for the lift. but i wanna drop it down and figure i may as well try the conversion now
Old Apr 28, 2013 | 12:15 PM
  #120
Atomic's Avatar
Wont be needing these anymore...
Each bar + key weighs 24.3lbs btw.
