Ditched the Torsion Bars for Coilovers on the HD
Old Apr 28, 2013 | 12:30 PM
  #121
moregrip's Avatar
what a rush!
what a tease....
Old Apr 28, 2013 | 12:47 PM
  #122
Atomic's Avatar
I have a gauge for that
Haha, Ill have a finished product tomorrow
...but wont have my engine back for a couple weeks, and would really rather test these out before I sell them
Old Apr 28, 2013 | 03:13 PM
  #123
kbracing96's Avatar
Send me a set and I'll put them on my truck
Old Apr 28, 2013 | 04:36 PM
  #124
Tydriver's Avatar
Originally Posted by moregrip
what a tease....
Agreed !
Are you planning on removing the torsion bar crossmember to ? I can see a weight savings there too.. Not sure if you're concerned about frame flexing if its removed or not ? (thinking out loud here-->) I guess you could devise some sort of tubular or boxed cross member to replace it an still have rigidity with an additional weight savings...
Old Apr 28, 2013 | 05:09 PM
  #125
tiffo60's Avatar
My truck had approximately 1450 on the fronts and 900 on the rears.
What spring rate did you go with?
Old Apr 28, 2013 | 09:45 PM
  #126
Atomic's Avatar
I will probably remove the crossmember...I am not too concerned about flexing since there is another crossmember right behind it.
I went with 1000lb springs because I wanted very little front end movement for launching and also the range of travel is not very much. I went with a shorter spring than recommended so I could more easily select the ride height I wanted.
I will make a thread later this week when I get it installed.
Old Apr 29, 2013 | 06:06 PM
  #127
midevil1's Avatar
torsion bar cross member provides no frame support whatsoever. throw it in the trash. From what I am told, the coil overs I did have 20K and counting. No shock tower failures..
Old Apr 29, 2013 | 10:15 PM
  #128
moregrip's Avatar
what a rush!
Any pics bro?
Old Apr 29, 2013 | 11:30 PM
  #129
2plus2's Avatar
intriguing thread
quick question..
Would it not be beneficial to use a progressive rate spring in a coil over setup? I noticed you guys are all talking about fixed rate springs. I was under the impression that the main disadvantage of a torsion setup was the lack of progressive rate springs
Old Apr 30, 2013 | 10:26 AM
  #130
Tootall's Avatar
got the email update . . . but no updates in the thread?
