blew driveshaft replaced it now leaking trans fluid
Old Nov 25, 2009 | 12:32 AM
m3srt's Avatar
Banned
Default blew driveshaft replaced it now leaking trans fluid
cut a long story short ... blew my driveshaft on the dyno took it to the dealer ... they said there wasnt any visible damage to the trans or rearend ... they replaced the d shaft got home and i noticed that i have a real slow trans fluid leak coming from the black rubber (seal) where the driveshaft goes into the trans ... im gonna call the dealer first thing in the morning and see what they say ... any suggestions of what this could be ?
and how to fix it
Old Nov 25, 2009 | 12:33 AM
GMCtrk's Avatar
simple. too much power
Old Nov 25, 2009 | 12:36 AM
GMCtrk's Avatar
ok, I couldn't resist lol.
You probably just need your rear seal replaced.
Old Nov 25, 2009 | 01:25 AM
lucky77's Avatar
Banned
they replaced the driveshaft?? are you for reals? even with cam/tune?
damn u lucky moffo....
ur lucky ur trans+ rear end din't go out.. when you blow ur shaft most of the times it takes part of the tranny + ur rear end messes up..
when i blew my shaft had that leaking problem u need 2 replace ur rear main seal.. its inside the that rear black rubber thingy..
post some picks of the carnage of the blown shaft
Old Nov 25, 2009 | 01:38 AM
m3srt's Avatar
Banned
is that hard to replace ???
heres the video and pics are in the vid
http://www.youtube.com/watch?v=oCrZkBVCdsQ
Old Nov 25, 2009 | 01:57 AM
lucky77's Avatar
Banned
well after my shaft blew...
couple of week's later my tranny blew.. so they rebuild everything- and replaced the seal...
what RPM did ur shaft blow?? its doesn't look that bad......
Old Nov 25, 2009 | 02:02 AM
lucky77's Avatar
Banned
here's a pic of my blown shaft @ 6400 on the street...
got me a build driveshaft - with 1350-slip/U-joints. . .
Old Nov 25, 2009 | 02:42 AM
A Low Dime's Avatar
13 Second Truck Club
Tooooooo Muuuuuuchhhhhh Poooowwwwaaaaaa!!!
Old Nov 25, 2009 | 03:50 AM
m3srt's Avatar
Banned
im not tryin to b corny , i wanna c how many hits i can get lololol ....
anyways how hard is it to replace this seal ???
Old Nov 25, 2009 | 09:40 AM
blue2003ls's Avatar
It's wasn’t too hard to replace on my 04. Remove the driveshaft and the seal can be pulled out with a standard screwdriver and tapped back in place with a dowel and hammer. I haven’t had a leak since.
