blew driveshaft replaced it now leaking trans fluid
#21
i will bring this up on friday
#24
Sorry that you're dealing with all this crap on a relatively new vehicle. I went through 2 GM 4L60e's, and they replaced them both. Just watch if they swap the trans, get the tune out of there. Get Charlie to hook you up with another PCM w/the stock tune. Just an idea.
#25
and come on guys. a dealer is doing warranty repairs on a modded truck. he should say thank you every time he picks it up.
#26
I'm pretty sure that there's a bushing in the tailshaft that can wear in these situations, someone please correct me if I'm wrong....but if I'm correct, before you replace the tailshaft seal, grab the driveshaft and move it up and down, if there' too much play, there is a bushing in the tailshaft that got wiped out when the driveshaft grenaded. You'll just end up with a new leaky seal if it needs the bushing...
*EDIT* you have to remove the tailshaft housing to replace that bushing btw...
#27
#28
it cost me 400 bux for a new d shaft .....
when i talked to them about the leak they said they will fix it .... but im gonan b pissed when i bring it in on friday they could have potentially blown my trans 4 me ... who knows i could have burned it up ,, driving the few miles i did ....
im just so depressed about the whole situation ... never had a big problem like this b4 .... its killing me ...
#29
*EDIT* I checked my 4L60E unit repair manual and there is a bushing in the tailshaft housing, not sure what it looks like as the pics are black and white graphics. I know that the old TH350's that I've pulled apart had brass bushings IIRC...
#30
Just going by experience. We have some idiots at the local stealerships that can't help plugging that computer in, even if it's not warranted. But just what if they do plug in and see the different shift points? Do you think that would have ever been questioned? I'm just asking.
Maybe your transmission is slipping now.
