Anyone have a P/N for 8.6 10 bolt pinion crush sleeve?
Old Jul 9, 2013 | 08:30 PM
thunder550's Avatar
High on diesel fumes
Default Anyone have a P/N for 8.6 10 bolt pinion crush sleeve?
Overtightened mine tonight
I need to get a new one, anyone have a GM PN? I checked with my local Napa today and they don't have one. Next stop is the dealer as long as they aren't crazy overpriced.
Old Jul 10, 2013 | 06:44 AM
Gadgetized's Avatar
My NAPA had one in stock, they might have one and not know where to look. I always get 2.
Old Jul 10, 2013 | 07:41 PM
They were very reasonable at my stealership...infact I got a nut there as well. LOL
Old Jul 10, 2013 | 08:37 PM
thunder550's Avatar
Dealer had one this morning for $15. I actually think the ones they had at Napa yesterday would have worked too, they didn't look right but I was remembering the length of the sleeve wrong.
Old Jul 11, 2013 | 07:00 AM
axisT6's Avatar
You should be fine if you got 20 in. lbs. If you do another diff, always have at least 2 crush sleeves. If you intend to enjoy beer while doing this, have at least 8.
Old Jul 11, 2013 | 07:28 AM
thunder550's Avatar
LOL thanks! I learned once not to drink and wrench, haven't made that mistake again
Old Jul 11, 2013 | 01:09 PM
Ferocity02's Avatar
How are you crushing the sleeve? When I did my gear install I couldn't crush it even with a 600 ft-lb impact gun, or with a floor jack under a 2' breaker bar with a 3' cheater. I ended up reusing the stock one and it's been fine for 10k+ miles.
Old Jul 11, 2013 | 02:26 PM
hog's Avatar
hog
In a pinch I've re-adjusted the crush sleeve over an old pinion gear. Lots of people simply reuse the old crush sleeve after adjusting it.
So long as you get the 15-20 inch/pounds for used bearings or 25 lnch/pounds for new bearings yo are golden.
peace
Hog
Old Jul 12, 2013 | 07:04 AM
axisT6's Avatar
peace
Hog
If you use a new crush sleeve, you have a higher preload on the pinion nut due to the force needed to crush said sleeve. The preload of the nut is good for a number of things like keeping the nut tight and preventing any kind of fatigue in the pinion snout.
Re-using a crush sleeve does not give this same preload.
Old Jul 18, 2013 | 12:13 PM
hog's Avatar
hog
That nut isn't going anywhere, I'm worried more about the bearing preload than preload on the nut.
Ive straightened them out, there is a force pushing back. But I do understand your point of the force not being the same between a new crush sleeve a reused crush sleeve that has already been crushed, then re-adjusted with the straightening, then re-crushed. The metal has been work hardened/fatigued for sure.
What is your opinion on using a solid spacer? I'm not sure I understand how that would work?
peace
Hog
flatblack83
Jan 3, 2026 07:10 PM
5.3Caprice
Nov 7, 2015 08:56 PM
SlicksNchicks
Aug 31, 2015 10:56 PM
YenkoST
Aug 28, 2015 01:42 PM
signguy62
Jul 27, 2015 03:42 PM
