Flip kit for 14 bolt rear end?
Old Aug 25, 2015 | 08:35 AM
YenkoST's Avatar
Default Flip kit for 14 bolt rear end?
I have a 2011 Silverado 1500 6.2L with the 14 bolt rear end. I have already done the 2" shackle, lift block removal, and clamped the leaf spring. Looking to go down from a 3.5-3.75" rear drop to a 5". I don't want to go to low since I tow a car hauler occasionally. I will be using air bags to help with this as well. But back to the question, does anyone know if the cups in the Belltech, McGaughy's, etc cup/saddle fits the 9.5" rear end in their kits? I've researched but couldn't find anyone that says if it does or doesn't. I would think that the kit is design majority for the 8.6" 10 bolt rear end so if the 14 bolt has a different part number, what would that be? Is the trans spacer a requirement at 5" for a crew cab?
I'm looking at the flip kit for the 4/5". The front is already dropped with 2" spindles but will be going down another 1" on the front with for a total of 3/5".
Thanks for the help!
Old Aug 25, 2015 | 05:06 PM
1FastBrick's Avatar
Custm2500's Rude Friend
You have to modify the saddles for the older 14 bolts. No one makes them this way AFAIK.
We had to do the same to a kit for the assassin bars to work on a 14 bolt.
The tube is larger as well as the u bolt hole spacing.
The newer 2005- Up AXN 14 bolts should have the same size tubes at the 10 bolt 8.625 rear end.
HTH
Old Aug 25, 2015 | 10:01 PM
YenkoST's Avatar
Gotcha. Thanks FastBrick. Didn't know that about the tubes. Its just the factory 14 bolt that came with the MaxTow package with the 6.2L. I tow a car hauler occasionally but 95% of the time, it's just my daily driver and would like to lower it a tad more than the 2/3.5" it's currently at without losing the ability to tow the car hauler.
Old Aug 25, 2015 | 10:08 PM
1FastBrick's Avatar
Should Have the RPO Code AXN in the glove box. I haven't seen one newer than 07-08 but the ones I have seen use a 10 bolt tube and they swedge the tubes out at the housing from just over 3 inch to like 3 1/4 to fit the cast housing.
Old Aug 28, 2015 | 08:46 AM
YenkoST's Avatar
It does have AXN in the glovebox FastBrick.
Old Aug 28, 2015 | 01:42 PM
1FastBrick's Avatar
I believe the tubes measure 3.105 od
So.cal Wrk Sled
Jul 26, 2015 12:10 AM
Ketis
Jul 23, 2015 12:37 PM
121
Jul 16, 2015 12:18 AM
Sdailey
Jul 13, 2015 09:17 PM
