Another 60e eats it
Old Jul 20, 2011 | 08:03 PM
jhe2003's Avatar
Default Another 60e eats it
Well, this past saturday it happened.....again. 2nd time. Got on it from a stop shifted to second and then BAM! No forward gears and no reverse
I'm talking to a shop about doing the 80e swap since the procharger will be going on soon so might as well right?
Truck is in the garage parked and will probably stay there for a couple of weeks until I decide what to do.
Old Jul 20, 2011 | 08:06 PM
Vince B's Avatar
What did you break last time? Pump or a shaft if I had to guess.
Old Jul 20, 2011 | 08:16 PM
jhe2003's Avatar
last time it was the input shaft, this time I dont know but I'm tired of this 60e!!
I wish I were closer to you so you could build me a badass tranny!! lol!
Old Jul 21, 2011 | 06:49 AM
Vince B's Avatar
If you broke an input shaft again this time around I would be looking to make sure that your TCC is not applied while the trans shifts.
Old Jul 21, 2011 | 07:58 PM
jhe2003's Avatar
thanks for you help! i'll make sure the tune is dead on when the 80e goes in!
Old Jul 21, 2011 | 08:12 PM
silverz28camaro's Avatar
I broke the input drum where the input shaft splines into the drum...split apart...This was in my 451 rwhp Camaro... I'm hoping that installing the sleeve kit from sonnax and the billet forward piston will fix my issue in my Camaro... Is that what broke in your last failure? or was it the shaft itself?
Old Jul 22, 2011 | 06:19 AM
Vince B's Avatar
Brad the reinforcement sleeve is a great upgrade and I use on many of my builds. In your case the drum might have just broke because it was weak from use, transmission shifting to hard, or TCC applied during a shift. It sounds like the parts you bought are going to help!
Old Jul 22, 2011 | 07:41 AM
2BFAST's Avatar
Steel meshed with aluminum isnt the strongest combination lol
Old Jul 22, 2011 | 11:44 AM
bud8fan's Avatar
no need to let it set....sounds like you have already made the choice...i really think you should do a 6L80E BUT A 4L80 will do...
pewter00
11
Oct 20, 2023 05:40 AM
turbo6c3
Oct 5, 2015 06:11 PM
twake_410
Sep 21, 2015 10:36 AM
Go5.3tt06
Sep 12, 2015 09:29 AM
pewter00
Sep 7, 2015 10:14 PM
