Another 60e eats it
Well, this past saturday it happened.....again. 2nd time. Got on it from a stop shifted to second and then BAM! No forward gears and no reverse
I'm talking to a shop about doing the 80e swap since the procharger will be going on soon so might as well right?
Truck is in the garage parked and will probably stay there for a couple of weeks until I decide what to do.
I broke the input drum where the input shaft splines into the drum...split apart...This was in my 451 rwhp Camaro... I'm hoping that installing the sleeve kit from sonnax and the billet forward piston will fix my issue in my Camaro... Is that what broke in your last failure? or was it the shaft itself?
Brad the reinforcement sleeve is a great upgrade and I use on many of my builds. In your case the drum might have just broke because it was weak from use, transmission shifting to hard, or TCC applied during a shift. It sounds like the parts you bought are going to help!
pewter00
11
Oct 20, 2023 05:40 AM
