4L60E slip w/radix install
Old May 16, 2005 | 11:45 PM
1SlowHoe's Avatar
Destroyer of Transmissions
Default 4L60E slip w/radix install
Put about 10 hard runs on the truck since the radix install (all street) Noticed a mild slip from 1st to 2nd at WOT today while merging. This is with only 4#'s of boost. At least I think it was slipping, felt like it took forever between gears ( 1-2 seconds) and quit pulling as hard. Gotta be slipping... Tranny has 62K miles.
Question 1: Should I drive it till it sh*ts or pull it now and try to do something with it (rebuild/sell)?
Question 2: When I install the new tranny and HD TC should I get a posi at the same time or will my g80 (if that is what I have???) hold up?
I'm only putting 300hp to the rear wheels, guessing, no dyno yet, but she's a heavy pig.
Old May 17, 2005 | 01:13 AM
CHarris's Avatar
Mine did the 1-2 slip pretty quick after I upped the boost on mine. I only had 2000 or so miles on the truck so we dropped the valve body and did all the billet parts and mods there. No problems since. I hate to say it but with 60k+ on yours I'd be thinking about a complete rebuilt with the good 65E parts and as many of the billet goodies as you can afford.
Old May 17, 2005 | 01:40 AM
Mr. Sandog's Avatar
What would you consider to be the complete list of "billet parts and mods"?
Old May 17, 2005 | 06:27 AM
1SlowHoe's Avatar
I've got the new tranny in the garage waiting to go in. Here are the parts it was built with:
Raybestoes Z-Pak with 13 clutches (replaces factory 5 clutches in the 3-4 drum)
All high temp, high energy clutches throughout the rest of the unit
All new steels, bands, bushings and rings
A .500 boost valve
10 vane pump rotor
4140 hardened pump rings
TEFLON pump bushing
29 element sprag
Sonnax WOT valve
Oversized hardened sun shell
Hardened input shaft and drums
5 pinion planetary gear
High temp pro series raybestoes kevlar band
Corvette servo
1-2 and 3-4 accumulators are blocked off
The builder assures me this thing is a rock and I won't have any issues. Warranty for one year, unlimited miles.
I was just wondering when I should swap? What are the signs that my stock tranny is about to fail? AND What should I do with the stocker? Rebuild or just sell it?
Old May 17, 2005 | 08:52 AM
onyx's Avatar
14 Second Truck Club
but in the end yopur still satisfied...
Old May 17, 2005 | 09:26 PM
1SlowHoe's Avatar
My tranny is slipping pretty good at WOT now. I guess shes about done. Around town, no problem - just the first to second @ 5800rpm. How long before this thing quits on me? I won't be able to get the better tranny in until week after next, if then. Am I gonna make it? I'm getting ready to drop the pulley from a 3.7 to a 3.4 tomorrow, I'm sure that won't help my cuase any. I'm only making 4-5 lbs of boost now and hoping for 7 lbs or so with the 3.4. Farewell stock tranny...
FOR SALE: Blown 4L60E
Old May 18, 2005 | 08:36 AM
zippy's Avatar
with any radix install should come a good shift kit. without it you might as well order a trans ahead of time.
Old May 18, 2005 | 09:01 PM
1SlowHoe's Avatar
I looked into a shift kit when I bought the radix. Was gonna be about $450 installed. So I checked out a whole new "built" tranny. Cost $1700 shipped, but I figured with over 60K on the stocker, half of that with my lead foot, I was probably due for a new one instead of a shift kit. If I can find 4 or 5 free hours I'd put it in. I'm just way toooooo busy. I just don't want my stocker to leave me walkin' cause I couldn't read the signs of the tranny failure getting closer.
ferrellrooster
Mar 6, 2025 03:22 PM
zblee
63
Jun 10, 2023 01:25 PM
wrb002
Aug 31, 2015 12:30 PM
Dezert1500
Jul 30, 2015 02:51 PM
