New inline fuel system
Old May 11, 2012 | 12:01 AM
Superado's Avatar
11 Second Truck Club
If anyone is wondering...
we drilled AND tapped the tank for 1/2" NPT and threaded the -10 x 1/2" NPT fittings into the tank using Seal-All as the sealant.
All fittings are Fragola except for the fuel rail adapter which is Russell 640850.
M18 copper gaskets are Dorman 2pk of oil drain plug gaskets. M12's come w/ pumps; however, using only one on the pressure side and tightened down well it still leaked. Put the extra one on that came in the hardware bag and added thread sealant on the threads and it sealed up nicely...not sure if it was the 2nd copper gasket or the sealant that did the trick.
Fuel filters are obviously from Summit...but price matched to Smiley's Racing Products (from $69 down to $49ea).
"Y" is from Smiley's Racing...would've had Summit match that too if I hadn't already bought it...cheapest one I've found...$20
Old May 11, 2012 | 11:04 AM
454SuperSport's Avatar
I think you might run into a problem with pressure creep running them both all the time, that's a ton of fuel for the stock fpr to bypass.
Old May 11, 2012 | 12:45 PM
nonnieselman's Avatar
if you had to guess, how thick is the tank where yall drilled it?
That looks like a great idea instead of trying to do a dual intake setup.
but then again if you had to brake hard you could starve them and have a air bubble in the line for a second.
Old May 11, 2012 | 04:41 PM
phasemaster1's Avatar
Only one thing I dont like. When I lost my driveshaft it slammed into and dented pretty good the metal plate where you ran the lines along the fuel tank.
Old May 12, 2012 | 03:56 PM
Superado's Avatar
We'll see (fingers and toes crossed)...not against installing an aftermarket FPR if this doesn't work.
Probaby 1/4" - 3/8"
Yeah...mine did the exact same thing. DS safety loop in the rear will be installed soon...OR...single DS and a safety loop.
Old May 13, 2012 | 07:44 PM
brandon6.0's Avatar
i like how u did this setup. My truck currently sits a lil lower in the rear thus creating issues with fuel starvation when tank is a lil low. Did this fix this issue for u? Im NA setup so i bet it was something to deal with being boosted.
Old May 13, 2012 | 08:01 PM
Beatdown Z's Avatar
Laid Back
Looks good. I put a -8an bulkhead fitting in the rear of my tank. Worked out pretty good.
Old May 13, 2012 | 08:38 PM
brandon6.0's Avatar
Did yall just leave the stock in tank bucket for fuel level sender? How did this setup work for being low on fuel? Did it starve any?
Old May 14, 2012 | 01:04 PM
Superado's Avatar
Thanks...and yes, it sucked fighting fuel issues!
Thanks!
Yes, we just disconnected the power wire before it entered the flange and terminated both wire ends...leaving everything else in tact to keep the level sender operable.
If I ever needed to hook it back up...I could do that pretty easily.
Old May 14, 2012 | 08:31 PM
99ta's Avatar
How loud are the pumps mounted outside the tank like that?
