fuel system help?
i have a 2004 gmc sierra with a 5.3 lm7 with a return-less fuel system. im currently running stock fuel rails, siemens deka 80lb injectors , walbro 400 fuel pump with the hotwire kit. im wanting to put in a boost controlled fuel pressure regulator but im not sure what one to go with. i been looking at the areomotive universal ones?
ive also been trying to cram info on all this but from what i gather is i will have to convert the system to a return style system and may also have to get some new fuel rails? if thats the case i think i got the rails picked out and i know if i need to convert it i can use a -6 line. but if i have to do this im not quite sure how to hook it up and run it. also dont know what all fittings id need and how long of hose? i appreciate the help guys.
im going to try ad have it tuned for 8psi for now until i can afford to do a returnless set up so far ive come up with this.
http://www.summitracing.com/parts/pf...make/chevrolet
http://www.summitracing.com/parts/maa-4305m/overview/
and a -6an line for the return.
ideas?
ideas?
do you by chance have any pictures on how you modded the top of the bucket and how you ran the return line? i know i wont need the bulkhead and stuff inside the bucket because im running the single. also what regulator did you end up going with?
I drilled a hole in the top for the bulkhead and wires. Thats it.
Return line follows the feed line that followed the factory fuel line path.
Aeromotive 13101 I think...
