Return-Style Fuel Conversion
Old Nov 2, 2010 | 01:43 AM
Atomic's Avatar
I have a gauge for that
Default Return-Style Fuel Conversion
So I will probably have to change from a returnless system to a return style once I get my new setup (shooting for 800rwhp if that tells you anything).
What I have in mind is dual in tank pumps with -8 off each to a single -10 Y in the bucket, then a -10 bulkhead fitting on top of the factory bucket, and a -6 for the return. -10 line from the tank to a fuel filter, then -10 line from the filter to the FPR (aeromotive 13101), and a Y from the -10 out of the FPR to dual -8 to the back of each rail (professional products 10614).
My issue right now is if I can use the factory bucket for the bulkhead fittings. Obviously I would get rid of the evap and factory fuel connector, but would I be able to use bulkhead fittings and have it seal completely with the factory bucket? If not, are there any aftermarket buckets available?
Old Nov 2, 2010 | 01:53 AM
Daryn's Avatar
Formerly darynC-10/23/10
i have my wiring coming through a small grommet where the evap sensor was on the gas tank.
IMO instead of running 2 pumps. i would just get the single 044 pump . thats what i have now
i also have the PP fuel rails and aeromotive bypass reg -6 feed -6 return
Old Nov 2, 2010 | 01:55 AM
Daryn's Avatar
heres a pic of how i have my reg set up . keep it as close the the rails as you can
http://i41.photobucket.com/albums/e2...e/000_0130.jpg
Old Nov 2, 2010 | 02:00 AM
Atomic's Avatar
I already have the pumps; a walbro 255 and a denso 1020, which supposedly flows more than the 044.
The part I am really concerned about is the bucket and if bulkhead fittings would work for the feed and return.
Old Nov 2, 2010 | 02:04 AM
Daryn's Avatar
i have my feed coming out the stock feed hole. and im using the evap purge ( the 1/2 port) as my return since i deleted the charcoal canister . im taking my bed back off this weekend or when it dries up from all this rain to re plumb with all stainless braided hose. ill take a snap shot
Old Nov 2, 2010 | 02:09 AM
Atomic's Avatar
Yea, that would be good. I have no problems with leaving the side hose to the canister, I just feel like I need the space where the evap connector is to use big bulkhead fittings like I want to.
Old Nov 3, 2010 | 03:15 PM
Rick_Vor's Avatar
I did some searching online and that Denso pump looks pretty potent. I know two 044's size pumps are too fat but it looks like it should squeeze in with a 255.
I have a 2005 bucket and there is plenty of room to add a #6 fitting. A #10 is another story. Keep us updated.
Rick
Old Nov 3, 2010 | 04:34 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
No need for -10 line IMO, people have made 1000rwhp on stock lines and dual pumps
Old Nov 3, 2010 | 04:40 PM
TIM Z's Avatar
11 sec. Truck Mod
You need to talk with Lonnie at Lonnies performance. Great guy who knows fuel systems on these trucks.
Old Nov 3, 2010 | 04:46 PM
black00chev's Avatar
Slowest turbo build ever!
as long as you keep constant fuel pressure i dont see why bigger would be better.
